custom tuning
Old Jun 4, 2007 | 04:41 PM
hispano1's Avatar
custom tuning
does anyone know if there's a problem when you do custom tuning from when you go to stock parts to a cai, 2.9 pulley and 42 lb injectors? is there going to be a lot of problems in the future since the boost is going to increase? should i be looking into a cooling mod before i start doing a custom tune??
Old Jun 4, 2007 | 04:49 PM
cobi's Avatar
you'll def want the custom tune ASAP, your car wont know its getting more fuel from those injectors.
Old Jun 4, 2007 | 05:05 PM
hispano1's Avatar
oh im fully aware of that but i've also been told that i'd need some cooling mod like the water/meth kit to make it 100% functional or else my car won't last as long?? is this true?? from stock to that size pulley and injectors, would it be about 5 lbs boost or more??
Old Jun 4, 2007 | 07:07 PM
cobi's Avatar
well youll def need to monitor things like knock, afr, and your intake temps. You may be able to get away without any cooling mods on a 2.9 safely but I would probably go for the dual pass intercooler mod.
Old Jun 4, 2007 | 07:39 PM
hispano1's Avatar
hmm that's what im trying to figure out if i'll be safe with out any cooling mods...how much do those dual pass run for??
Old Jun 4, 2007 | 07:49 PM
CbYellowSS's Avatar
they are like 250 look on cobalt addiction
Old Jun 4, 2007 | 08:04 PM
DaREDss's Avatar
kid near me runs 2.85 and stage1 with no problems
does the ca front mount intercooler make a diiference is worth 350 bucks?
Old Jun 4, 2007 | 08:14 PM
hispano1's Avatar
has there been anyone with a custom tune with out any cooling mods done??
Old Jun 4, 2007 | 08:22 PM
braineater's Avatar
me! no problems so far.
Old Jun 4, 2007 | 08:29 PM
hispano1's Avatar
what size pulley are you running?? what are your numbers and what program did they use? the local shop here says they'll be using EFIlive and its better then hptuners...
Old Jun 4, 2007 | 08:33 PM
Mikey851's Avatar
You should be okay with a 2.9". Run 93 octane and go 1 step colder spark plugs. Methanol is purely optional on a 2.9" pulley, you don't need it.
A cheap cooling mod you could do is to get another coolant surge tank and hook it up in series with your intercooler. This will allow higher coolant/water capacity and the ability to use ice if you want.
Old Jun 4, 2007 | 08:40 PM
braineater's Avatar
i am still using the stock pulley, i have no clue what the numbers are, a friend of mine tuned it with a program called..umm.. hptuners i think?
Old Jun 4, 2007 | 08:46 PM
hispano1's Avatar
ok thanks, thats some great info, the guy told me that there's a chance the car wont last without some cooling mods if i'm hitting 18 lbs from 12 lbs of being stock..
Old Jun 4, 2007 | 10:23 PM
cobi's Avatar
uhhh last time I checked EFIlive cannot be used on any GM 4 cyl.
IIRC hptuners is your one and only option.
Old Jun 4, 2007 | 10:35 PM
Ron9919's Avatar
i do tune cars if anybody needs one!!
Old Jun 4, 2007 | 11:48 PM
PuSha050's Avatar
i have a custom tune, 3" pulley 42 lb injectors and catless downpipe, no cooling mods.. and my car runs great
Old Jun 5, 2007 | 12:07 AM
hispano1's Avatar
and it's with hptuners as well?? why isn't efilive compatible with gm 4cyl? the guy i spoke to sounded that he actually knew what he was talking about and saying that it should work?? no cooling mods or burning rich or anything with your custom tune?
Old Jun 5, 2007 | 08:32 AM
cobi's Avatar
Yah I had a friend who went to tech school and was blabbing left and right about EFIlive and I said I dont think it works for my car bud. He kept goin on and on about it so I finally looked at their website and couldnt find anything for our cars................
Ok I take that back, I just now looked and since the last time I've checked (about 4-5 months ago) it looks like the 2.0L LSJ is now supported but nothing else. I wonder if anyone else has used this?
Im still not sure if you are able to tune with this though. Anyone know more about EFILive and the LSJ?
Old Jun 5, 2007 | 09:48 AM
PuSha050's Avatar
i dono about EFIlive but im tuned with hptuners.. absolutely no problems
Old Jun 5, 2007 | 01:30 PM
hispano1's Avatar
i just called the shop and they are stating that if i'm going from 12-12.5 lbs of boost to 18-19 lbs of boost, its the best decision to get a cooling mod or else it wouldnt be as best of a tune and the car would run smoother..is that true??
Old Jun 5, 2007 | 01:38 PM
cobi's Avatar
uhhhh if your hitting 18-19 psi then yeah you def need cooling mods but a 2.9" pulley will not get you there.
Old Jun 5, 2007 | 04:06 PM
braineater's Avatar
yup.
Old Jun 5, 2007 | 06:15 PM
hispano1's Avatar
ok..what is more realistic boost for stage 2 then?? 15 lbs??
Old Jun 5, 2007 | 11:21 PM
PuSha050's Avatar
yea i hit like 15.5, 16
Old Jun 5, 2007 | 11:24 PM
hispano1's Avatar
and that's with the stage 2 or custom tune??
