cv axle seal
cv axle seal
i've been leaking tranny fluid since i snaped my cv's. its just a little bit, but i know i need to replace that seal in there. has anyone done this? im searching for it, but just seeing if anyone done this and if its a pain or pretty simple...
looks like im needing this part# 55353153. its a seal..if you look at the differental assembly thats where you will find the part.
http://www.thesaabsite.com/93/93manu...nparts03on.htm
i believe you remove the shaft and use a seal removal tool looks like the claw on a hammer on both sides then use a seal driver to reinstall them... i havent got around to installing mine yet the dealer denied my warranty on them bc i had sportlines
see im wondering if i could take mine in and have them replaced under that power train warranty. but i installed ottp stage1 axles. do u think i would get denied?
yep. they denied me even before they knew i had sportlines and that was b2b warranty! they said it was normal for them to leak a little bit and dont need changed till its a rapid leak or streaming thats when i got mad and raised my voice asking why? so you can put a new transmission in? by then its too ******* late and you dont realize your transmission is out of the 1.7 qts (f23)
Sl0wbaltSS
Nov 21, 2018 11:11 PM
DANRICKARD
Oct 1, 2015 12:08 AM
