is it dangerous ?
Old Aug 25, 2010 | 04:11 PM
max400's Avatar
is it dangerous ?
is there a possibility to broke the engine if i`m using the wrong nozzle size for methanol injection ( too big ) ? i`m asking because last week my engine broke and the shop was tuning the car for methanol. 75 meth 25 water 7gph nozzle but the car was fine 23 timing no knock afr 11.2-11.0 but then all the oil go out by the dipstick and the piston #4 was gone..... my setup: full exhaust 3` no cat ,intake,2.7 pulley zzp stage 3 he and meth
Old Aug 25, 2010 | 04:16 PM
DjJoeski87's Avatar
raptors_67's Avatar
I'm using a 7gph and I know others using much larger nozzles. Don't see how it can cause damage like that other than flooding the motor if the pump never shuts off. The shop doing the work is most likely to blame, too much timing/lean AFR will crack that piston.
Old Aug 25, 2010 | 04:29 PM
SS Pyro IV's Avatar
too much naaaawwwwwzzzz
Old Aug 25, 2010 | 04:50 PM
Bluelightning's Avatar
Got Bewst?
I'm using a 7gph nozzle as well. Too much meth will just cause you're motor to bog out. Unless you're check valve fails and fills you're intake with meth. Then it can cause engine damage if it hydro locks
Old Aug 25, 2010 | 05:21 PM
max400's Avatar
ok that`s what i thought thank you guys !!!
Old Aug 27, 2010 | 11:16 AM
ebristol's Avatar
The answer to this question is no. If your afr was in the 11s your engine should have been fine.
Most likely your engine had a problem before it was tuned for meth injection.
Old Aug 27, 2010 | 05:34 PM
max400's Avatar
i`m pretty sure to, because when i bought the car (used) there was a strange noise in the supercharger. They change it under warranty (6000$ canadian) but if the supercharge was dead there is a good chance that the engine was tired to.
satisfied
Oct 19, 2015 12:35 AM
Flash~SS2.4
Canadian Mid East
Jun 24, 2007 06:47 PM
