devils own meth
devils own meth
guys, im looking for a meth kit, devils owns seems to be the one i wanna go with, this will be almost my last mod before a trifecta tune. i wanna get a meth system so i can set it to kick on at say 6PSI, my car will have the m62 with a 3.0 pulley. max boost should be around 16 PSI? i basically wanna make sure i get the right kit, i was thinking the stage 1, but not sure if i can set it to kick on at 6 PSI. heres what i think i need.
Universal Stage 1 : Methanol Injection Kits : DevilsOwn Alcohol Injection
2.5 Gallon Sumped Tank
Outside Mount Nozzles - DO3 - DevilsOwn Injection
I run the Stage 1 Devil's Own kit. You can set it as low as 5 psi. I tapped into my windshield washer tank and mounted the pump behind the right headlight. It's a great kit. Never had any issues with it. What I would suggest for a piece of mind is tapping in a pressure switch and running a red led into your cab so you know the pump is on and working. Better safe then sorry
. Oh and the kits comes with 3 and 7 gph nozzles.
I have the devils own dvc-30 stage 2 progressive kit with the 2.5 gallon tank. I'm running a 75% mixture with a 2.7 and other mods but I love it. Keeps everything running good and I have 25* of timing.
ok looks like the staeg one will do the trick since it comes with the nozzle i need anyways the 3.0. as far as wiring up a led light, where can i get that and everything else i need? thanks guys!!
The stage 1 you have to cut a maf wire so it reads when to spray, I got the dvc-30 kit. It's really simple to hook up, the hardest part for me was trying to figure out where I wanted to mount the big ass tank.
This:
DVC-30 methanol Injection Kits : DevilsOwn water Injection
This:
ok so the kit you go theres no cutting and splicing wires, just hooked up to vaccume, correct? i do understand there may be splicing of the wires for the controller itself, but no wires that are already on car.?
send blackcobalt707 a pm, he got me a great deal on the kit and tank. He's a dealer for devils own, I think it was $425 shipped for the kit and the 2.5 gallon tank, just tell him i told you about it!!
you can find him in this thread:
https://www.cobaltss.net/forums/nort.../index404.html
The light tells you there's power going to the pump but doesn't tell you if the pump is working. I used to have my light set up that way till I had a close call with my pump quitting.
