Did i put this hub on right?
first time putting hub on and pulley was attached to it that way so thats the way i stuck it on. Is this the right way or is it backwards and does it need to go on farther?
trying to shimmy your hand down the side to get belt on the lower crankshaft pulley. Taking off the supercharger pulley then making the belt tight so it does not come off down there will make it so much easier to put back on in the end. Get some rope or something to tie it up temporarly. Good luck. Also this is just future reference cause it sounds like you already have it all the way off lol.
He's so right this will save you from punching your self in the face
If you can't figure it out this should help you.
http://www.gmperformancedivision.com...J_Chap_3&4.pdf
They cover installing a stage 2 belt in this.
You could have contacted me regarding this man. Glad the tool worked out for you, however the hub should have been pressed on then the pulley attached. Granted it didnt happen to you this time but you could have damaged the hub pulley and shaft. So if you go to help out anyone else make sure just to push the hub on first then attach the pulley just my .02
Let us know if you start to notice a fine black power on the snout or pulley. If its off by a little it'll start to chew on the belt. From the sound of things yesterday I think you'll be fine though.
