Diy: Meth inj.
Old Nov 23, 2009 | 09:50 PM
rkenny97's Avatar
Diy: Meth inj.
my friend said i could just by the pump run it from my washer fluid tank is this correct and if so how would i go about it. other than a throttle body spacer can i put it in somewhere else? what would i use on the sprayer side? my friend just has me thinking. if this sounds about right help would be great on how to hook it up. thanks ronnie
Old Nov 23, 2009 | 11:27 PM
schamsy's Avatar
I was wondering the same thing because I want to do the same... You could just tap into the air intake???
I know you would need a controller so it was progressive or only hit when boost hits like 5 psi.
Old Nov 23, 2009 | 11:37 PM
Jn2's Avatar
Jn2
Just buy a kit bc it comes with the controller so it activates at a certain psi. That way u can tune for it. a decent meth mix will lower ur a/f...
Old Nov 24, 2009 | 10:52 PM
rkenny97's Avatar
so nobody has done this?
Old Nov 25, 2009 | 08:53 AM
383_Stroker's Avatar
the washer fluid pump will not have enough pressure to atomize the fuel.. so it will be spraying droplets of methanol into the engine, instead of a mist...
I did a DIY kit, but bought a real pump to go in it.
Old Nov 25, 2009 | 12:22 PM
advise's Avatar
where did you get the pump and the pressure switch
Old Nov 25, 2009 | 12:26 PM
selfinfliction's Avatar
my washer tank is tapped, just buy a fitting and tap a low spot on the tank, i tapped it about an inch above the fluid pump, that way if any junk gets in the tank, it won't be sucked up into the meth pump.
mine was a coolingmist kit, not even sure if they're still in business or not
Old Nov 25, 2009 | 12:28 PM
rossshady120's Avatar
how am i suppose to wash my windows? Also i heard meth kits were only effective when your at open throttle.
Old Nov 25, 2009 | 02:43 PM
uhhh well you flip the lever that squirts your windows, and washer fluid sprays out and the wipers go back and forth. or you can stop at the local gas station and use a squeegee <sp>
there are types of washer fluid that have alcohol in them, think there is a thread somewhere listing the brands/types that you can use and the quantity of alky mixed in them
Old Nov 25, 2009 | 04:34 PM
rkenny97's Avatar
ok so if i buy a pump and switch then what type o nozzle do i use?
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
