Do I have everything??
I am planning on installing some parts and getting a tune I want to know if I have everything I need. Here's the total parts list:
2.6
60's
Injen intake
Dual pass
Cx h/e
Stu mod
Pacesetter headers
2.5" catless dp
2.5" catback
Aem meth kit
Aem uego wideband
I am thinking that is everything I need I don't want to schedule a day to get tuned and show up not ready. Is there anything I need or anything that would be a good idea to add on to the list b4 I get tuned.
2.6
60's
Injen intake
Dual pass
Cx h/e
Stu mod
Pacesetter headers
2.5" catless dp
2.5" catback
Aem meth kit
Aem uego wideband
2.6
60's
Injen intake
Dual pass
Cx h/e
Stu mod
Pacesetter headers
2.5" catless dp
2.5" catback
Aem meth kit
Aem uego wideband
2.6
60's
Injen intake
Dual pass
Cx h/e
Stu mod
Pacesetter headers
2.5" catless dp
2.5" catback
Aem meth kit
Aem uego wideband
- Hydroshield for your Injen
- Various sizes of hose clamps. Maybe some extra hoses
- Fuel Injector gaskets for your 60s,
- A pully puller for your 2.6" Pully
- A new Supercharger gasket for when you pull your supercharger off the intake manifold and put it back on so you can get your pully swapped out.
- Undersized belt, or an over size tensioner.
- Various harware and such.
- Might want to get an Interceptor, that can help read your IAT2s, your KR, you can hook up your Meth pressure sensor to it, as well as your AFR with various kits from Aeroforce.
- DeXcool 50/50 premix, or DexCool Concentrate, and a gallon of distilled water to refill your SC/HE/Innercooler system.
- At least 1 heat range cooler spark plugs
- Intake gasket for when you take your intake out to do your dual pass
- Gasket for the lavamor cores (sp?)
- Exhaust Gasket for your Header
- Throttle body cleaner. Since your takeing off your SC and your Intake, youll have to pull out your TB anyway, sicne they get dirty easily in our cars, its a good time to clean it.
- Dual or Tripple pod Apiller. depending if you get an interceptor, keep the stock boost gauge and have your Wideband gauge sepret from the interceptor if you choose.
- Some Injectors require an upgraded wire harness as well.
- PaceSetter Performance Website said that their headers do not include header bolts... so might want some of those.
OP you should have purchased a 3" downpipe. A 2.5" downpipe is not an ideal size for the ss/sc.
The stock ss/sc catback is not a "true" 2.5" exhaust. The inlet of the resonator is only 2 1/16" i.d., and the over axle piping necks down to 2.25". So adding a true 2.5" catback will net a few more horsepower over stock.
Just off the top of my head, you might want
Is this necessary?
What is this for? Sorry I forgot to mention the dual pass, h/e, and stu mod are already installed.
Also forgot to mention I have 60s and 2.8 currently on installed
This was a question I forgot to ask, I have a stg2 belt do I also need an oversized pulley?
Is this necessary to have in order to get tuned
Is this necessary?
The hydroshield is a nice item to have just for piece of mind when driving in the rain. Injen intakes now run a dryflow type filter, and they will soak up water like a sponge vs. an oiled k&n style filter.
You dont need an interceptor to get tuned, but if you are going to be running a tune its nice to have a gauge that will monitor all of your tuning parameters.
A 2.6 pulley w/o an over sized or adjustable tensioner could lead to belt slip. The GMS2 belt is usually good down to a 2.7" pulley. Although some have run the GMS2 belt on a 2.6 pulley w/o issue.
if u dont alrdy have i would suggest some rotated mounts to get rid of wheel hop and help put that power to the ground without shaking **** up too much.
the interceptor IMO is a must for anyone who has a tune. for your application i wouldnt drive down the street with a 2.6 on without knowing if i got KR or seeing my IATs. intake air temp being high bc ur intercooler pump is dead can blow up an engine. heat in combination with bad tunes/knock are the reason people blow their sleeves.
1 Post
dont bother with a hydroshield, its a waste of money. I never had one and i drove in the rain alot, on the highways and in flooded areas in the city. Never once did my filter get water near it.
The interceptor gauge isnt 100% for tuning. But is recommended afterwords. While you are being tuned, whoever your tuner is will be able to see all that data on his laptop. Although after your tune, **** happends and its a good idea to be able to monitor it, especially your IAT2 and KR.
And be prepaired for a loud/ricey sounding exhaust if you are going with a 3" dp and 3" exhaust. I have yet to hear a good sounding 3" system on a SS/SC.
I dont see how you could say your filter never got wet unless you physically checked it by removing the inner fender liner. Trust me water gets in there and on the filter. I have witnessed a few people that ruined MAF sensor due to not running a hydroshield on there ss/sc intakes. If you have an oiled filter you wont have to worry as much, because the oil will repell most of the water that splashes on the filter, but that isnt the case with dryflow filters. Better safe than sorry. Not to mention hydroshields keep the filter cleaner longer which is another plus.
I had a 2.8 with the GMS2 belt until a couple days ago. I was getting a lot of belt squeeking, so I ordered an oversized pulley from ZZP. It was/is a very tight fit, but I am now running both the stage 2 belt and the oversized pulley. The squeek is gone so far. Hopefully, its not too much pressure on any bearings, etc.
2.6
60's
Injen intake
Dual pass
Cx h/e
Stu mod
Pacesetter headers
2.5" catless dp
2.5" catback
Aem meth kit
Aem uego wideband
2.6
60's
Injen intake
Dual pass
Cx h/e
Stu mod
Pacesetter headers
2.5" catless dp
2.5" catback
Aem meth kit
Aem uego wideband
I would go with a different H/E setup personally, since you will be creating some serious heat. other than that, TRACTION mods and a new clutch should be your next mods : )
1 Post
Do you own an SS/SC?
Now im not sayin its never happend to everyone, but everyone that i know that had a SS/SC, never had issues.
1 Post
randoms072.jpg picture by Snakes709 - Photobucket
Unless you are driving in water that is high enough to reach your filter...approx 1-1/2 feet, i dont see how water will get sucked up.
1 Post
Get the ******* hydroshield. The 20$ is worth it. Why chance sucking up water. Only bad things can happen. Take it from a guy who ruined 2 MAF sensors in 2 months because of it. Got the shield, and no issues in a year.
