Do you guys think this will help our cars?
Well I have been thinking long and hard about nitrous and honestly Im just to scared to go that route. But in my research of nitrous I ran across this
The CryO2 Air Intake consists of an aerodynamically designed bulb with a cryogenic chamber which is mounted in a 4" segment of air tube. The air passes over the bulb, heat is removed from the air charge resulting in a colder, denser, more powerful charge. Dyno testing showed a reduction in intake air temperature of more than 50 degrees. The CryO2 Air Intake can be used on turbocharged, supercharged or naturally aspirated applications. Multiple units can be used for colder results. Installs in minutes and comes with silicone connection sleeve, hose clamps and connection / vent hose.
Do you guys think this would help our cars in any way?
Use the search, there are a few threads discussing this topic already. Yes it will work but I dont think it will work well enough to offset the cost. And keep in mind the 50 degrees colder would most likely be a turbocharged application, ours is much different
Thanks bro Ill search it on here.
Getaway_Driver
40
09-10-2015 09:11 AM
