does the crankshaft pulley have a vibration dampener?
Yes, the crankshaft pulley is a DAMPER (dampeners get things wet, dampers lower the amplitude of vibration). Because this is a 4 cylinder, there is not a lot of inertia on these dampers. There is rubber between the hub and the inertia ring which created the damping. I know that our company (make vibration dampers) does not make this one, but I have quoted it in the past when GM wanted to do some market studies to get better pricing from Metaldyne and Hillsdale Automotive. Most engines that are made today have a crank damper. The twisting of the crankshaft that is created by the flywheel trying to keep the engine turning and the cylinders firing produces a resonance at some frequency. I believe, but don't quote me since it has been a while since I have seen the prints, that this engine is right around 300-325Hz. The fact that is is supercharged will increase the cylinder pressures and the magnitude of the tosional vibrations.
I don't think that removing it will drastically change any performance for the better.
A Light flywheel is about as much as you should shave off the rotational mass unless you plan to strip it down to a track only car..
Originally Posted by eirhed
The only problem with a light weight flywheel is that the damper is tuned to the stock mass-elastic system..... (Not A Good Idea) (Car Needs THis To Function Properly)
That is basically what I was trying to say "I don't think that removing it will drastically change any performance for the better"
as in Negative performance...
Good and clear post BTW..
patooyee
Oct 1, 2015 01:07 PM
