down pipe question
Old Jul 25, 2012 | 10:14 PM
ultimategnar's Avatar
down pipe question
got a question i put on a 2.5 catted zzp down pipe. planning on goin 2.9 and 60's (60's so i have plenty of injector for future changes) is a 2.5" down pipe good enough? the reason i did not go with the 3" is i have had problems in the past on my other ecotec cars with going to big on the exhaust and loosing power over it. i didnt feel that a 2.9" pulley would require a 3" exhaust i think a 2.5" is fine.
what does everyone else think?
Old Jul 25, 2012 | 10:35 PM
D Boogie C's Avatar
3" downpipe and 2.5" exhaust.
Old Jul 25, 2012 | 10:49 PM
Cobe's Avatar
You will be fine with a full 2.5 in exhaust mani or header. Untill you go TVS then I would go 3in downpipe and 2.5in cat back
Old Jul 25, 2012 | 11:06 PM
Bluelightning's Avatar
Got Bewst?
This ^^^
Old Jul 25, 2012 | 11:46 PM
Cobe's Avatar
This ^^^
even on stock m62?
Old Jul 25, 2012 | 11:49 PM
Killa SS's Avatar
Lnf! Gtfo of our ****!!
Old Jul 25, 2012 | 11:53 PM
aikidoshadow's Avatar
this^^^ since youre getting the injectors to grow on this would be a similar mod
Header with a 3" collector, a 3" downpipe, and a 2.5 catback will be good even with a TVS until you start really dropping pulleys.
lmao
Last edited by aikidoshadow; Jul 25, 2012 at 11:53 PM. Reason: Automerged Doublepost
Old Jul 26, 2012 | 12:00 AM
Cobe's Avatar
In all honesty i purposely commented on this waiting for a comment from your or 07lsj to say this hahahah!!
Old Jul 26, 2012 | 12:03 AM
Killa SS's Avatar
My job is to troll you. you may want to look into a restraining order. lol
Old Jul 26, 2012 | 12:09 AM
Killa SS's Avatar
Old Jul 26, 2012 | 12:10 AM
Cobe's Avatar
Hahahah
Old Jul 26, 2012 | 12:17 AM
Sir_Hiro's Avatar
I have the same mods as you..and I have the 2.5 and I have no loss in power..your fine for now.
Old Jul 26, 2012 | 12:20 AM
Killa SS's Avatar
haha slow balts with 2.5in exhaust. peewee exhausts
Old Jul 26, 2012 | 12:23 AM
tru2nrtt777's Avatar
Technical Articles
For those too lazy and this works for non turbo apps too:
"Pipe diameter does have an effect on flow rates as well, but again it is not the major factor in most cases. 2.5" may flow enough for 300-350 h.p. without being a restriction. 3" is usually capable of flowing 500-600 h.p. before becoming a restriction. This is assuming that you have designed the rest of the system up to par. There are also full 3.5" systems and those that start out at 4" and taper down. Unless you are making over 500-600 h.p. anything over 3" is a case of diminishing returns and in most cases has no advantage. There is more to gain going from 2.5" up to 3" than there is going from 3" to 3.5". A 3" system will not loose torque compared to a 2.5" system if designed properly. In fact if designed properly 3" may be capable of making better low end torque than 2.5". Again, since the way to make the most torque with a turbo exhaust is to get the turbo to spool-up as quickly as possible, it should be the main goal of the entire exhaust system and good flow after the turbo is one way to achieve it. We use 3" as we want our system to flow enough to be capable of coping with a customer's changing goals. Properly designed we can offer it to the big power crowd while still appeasing the low end torque club.
The only reason to reduce the size towards the end of the pipe is for packaging, cost, and noise reasons. Tapering the diameter does not make more power, torque, or bring on boost faster. However having smaller pipe towards the end has less effect that having smaller piping at the beginning. In other words a system that has 3" pipe for the majority, and necks down to 2.5" at the end will flow enough for more power than a complete 2.5" system. The further downstream you neck down the exhaust the better……..if you decide to neck it down."
Old Jul 26, 2012 | 07:26 AM
hey thanks for the responses.
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
717ssbalt
Oct 2, 2015 04:01 PM
