downpipe
Old Jan 14, 2010 | 06:59 PM
BlackJackSS's Avatar
downpipe
i got a quick question about my downpipe.
it sounds like ive got a leak while im driving and i cant tell where from. i put RTV all over the flange for extra sealing but i dont know if that worked or not..
i only get the noise at about half throttle. think it could be from not getting the o2 sensor tight enough??
Old Jan 14, 2010 | 07:01 PM
elite_Cyborg's Avatar
have someone drive while you ride under it on a creeper. that way you get real results
Old Jan 14, 2010 | 07:04 PM
u would be my first candidate for that.
Old Jan 14, 2010 | 07:08 PM
xcmx's Avatar
if you dont have any solid mounts u probably cracked ur flex pipe. its very common mine went about 30K. if its the factory dp. its covered under a 80k mile cat warrenty. with the engines moving around so much with rubber mounts the "flex" pipe cracks.. the rtv wont hold because there is too much pressure. either take it to the stealership or buy a aftermarket one..
Old Jan 14, 2010 | 07:10 PM
it is an aftermarket one... sorry i didnt add that. and i do have the solid mounts.
ill figure it out. if all else fails ill weld the bitch.
Old Jan 14, 2010 | 09:28 PM
Supercharged Guy's Avatar
lol yeah just weld it..problem solved
Old Jan 14, 2010 | 09:36 PM
Sizzle06's Avatar
I had the same problem,pulled the dp and i had a blown gasket from the header to dp.
Old Jan 14, 2010 | 09:45 PM
ddsscobalt's Avatar
i have the same problem.. my dp flange and catback flange dont meet very well... i have a gasket and rtv and it lasted about a month before it started leaking again... i dont wanna weld it but im probably going to do it anyways because its an annoying sound
no_ss
Oct 18, 2015 11:58 PM
nathan112i
Sep 30, 2015 07:12 PM
09SSlow
Sep 28, 2015 12:37 AM
riceburner
Sep 27, 2015 11:10 PM
