Which Downpipe To Pick?!
Old Jan 14, 2007 | 06:26 AM
2006ArrivalBlueSS's Avatar
Originally Posted by NGalaxyTimmyo
Give Kenny a call, or get into contact with Donna and she'll pass it on. Just tell them that you want a second bung welded in for a A/F gauge. I think it's a little extra, but your gonna have to pay to get it welded in anyways. I went with the catless, so I don't know how much room is left. I'm sure they know what they're doing though.
Kenny quoted me $15 to weld in a bung before the cat
Old Jan 14, 2007 | 09:11 AM
NGalaxyTimmyo's Avatar
I believe anyone I've asked quoted me around $30, so thats damn good then.
Old Jan 14, 2007 | 09:20 AM
KangolRiot's Avatar
I talked to Kenny and he said it shouldnt throw codes with the GM Stage 2 kit/reflash... I will be installing my xtc downpipe and header on jan 23rd
Old Jan 14, 2007 | 11:44 AM
TxLonghorn#1's Avatar
does anybody know what is the best set-up for headers and a downpipe....ie prices & gains??
Old Jan 14, 2007 | 02:53 PM
hatrickstu's Avatar
Originally Posted by LSJFury
Does that mean that the XTC DP is one of the ones that throw codes? Even with the Catalytic Converter? I need a DP that has a Cat. Conv. and doesn't throw any codes...
without a cat looks like it will throw, i dont know about if it has one
Old Jan 14, 2007 | 03:10 PM
Cobalt_SSTuner's Avatar
has anybody heard anything about the zzp downpipe?
Old Jan 14, 2007 | 03:43 PM
kenhebe's Avatar
I thought the GMPP catback system came with a downpipe? Please bitch slap me if I am incorrect.
Old Jan 14, 2007 | 09:46 PM
BLKblurr06's Avatar
Originally Posted by Boost Fr33k
dude all im hearing is that the zzp downpipe is producing mad noise... but im looking at intenses and its looks legit for $200.00 but i want some feedback first.
intense downpipes have no cat in them
Old Jan 14, 2007 | 09:53 PM
hatrickstu's Avatar
wish you were closer
Old Jan 14, 2007 | 09:54 PM
Johnboy12358's Avatar
it does not, the gmpp exhaust is from the downpipe back
Old Jan 14, 2007 | 10:28 PM
  #36
sushidog's Avatar
The 2.5" XTC downpipe w/cat will throw a p0420 (low cat efficiency) code on the 2.4, but not on the 2.0. The ECM is more sensitive to triggering this code on the 2.4, from what I understand. If it does pop a CEL, hp tuners can turn it off. There are other devices (both electrical and mechanical) available to avoid the code too.
This is one: http://www.o2sensorsimulator.com/?gc...FSREgQod5XiaLg
Here's another: http://cgi.ebay.com/ebaymotors/CHECK...67820810QQrdZ1
Old Jan 15, 2007 | 12:07 AM
  #37
So the ZZP downpipe doesnt sound good??
Old Jan 15, 2007 | 10:15 AM
  #38
SMG Autosports's Avatar
Some of you might want to check out our myspace page... and look at our newest blog. Prices will be competitive so have no fears.
Old Jan 15, 2007 | 12:52 PM
  #39
mcphatty's Avatar
so why exactly is everyone saying to go with a downpipe with a cat? just for emissions reasons or is there some sort of performance advantage to having one as opposed to not
Old Jan 15, 2007 | 04:25 PM
  #40
Ok. I see a lot of missing information when it comes to cats and no cats. First off, if you get a catless downpipe, Yes, you will get a code. Is it the end of the world? no. All it's saying is that that cat isn't working correctly. Well, it shouldn't be. You don't have one.
There are 3 codes related to the Cat. I don't have my list next to me right now, so I don't know which one's they are. I think they're something like P0038 and 39, and then another further down the list. Once again, I'm not sure on this, so don't sue me if I'm wrong.
::EDIT:: I've looked up the codes. They are
P0036
P0140
P0141::
If you get the Downpipe with cat, it shouldn't throw the code. A cat is only there for emission reasons. So if you live in a state where you have to get checked every year, don't go catless. If you live a great state like Michigan, where they don't test, go ahead and get catless.
What will happen to your supercharged car when you go catless? Well, there is one more thing blocking the exhaust. Due to this, you will see a decrease in BOOST. However, that doesn't matter, cause you still have the same amount of air going into the engine. It's just easier for it too leave as well. You will be making the same/more power with less boost. This is great for the 2.5 and 2.6 pulley, as it's less pressure on your engine.
Lets go back to the codes for a moment. One of the codes is for the Cat heater. The cat only works properly once it's heated up. If you disconnect the second 02 sensor like I have, you will get this code because it's not able to heat it up. Another code I believe is for the heater working as well, with the last one being for the cat working properly itself.
If anyone has any questions about cat-less, ask away. I have a video up on You tube before and after installing my cat-less downpipe.
Corsa Sport with cat
Carsa Sport without Cat
It's more noticeable in person then it is on video. Also, the surge you hear at idle was due to a bad injector, not the cat, so don't let that sway your opinion.
Once again, please correct anything if I'm wrong.
Old Jan 15, 2007 | 04:37 PM
  #41
Cipher117's Avatar
hmm.... what about hahn's downpipe? it comes with a cat
Old Jan 15, 2007 | 05:18 PM
  #42
Boost Fr33k's Avatar
good info
one question though. i should probably install the full exhaust from headers to dp to catback then install my wideband so they can set up some sensors to get some readings, right? or it wouldnt make a difference now or after.
Old Jan 15, 2007 | 05:38 PM
  #43
I'm kinda confused by what your saying. Are you asking if you should wait until you have a full exhaust to get an A/f gauge?
It doesn't matter when. I still have the stock header on. When you go to install a bung for the A/f gauge, it goes in the downpipe, so make sure you don't plan on changing this once you do it. The gauge I have, The AEM one, states in the instructions the range away from the header.
Anyway you go, if you plan on doing any tuning, get an A/F gauge. And please, make sure it's a wideband.
Old Jan 15, 2007 | 06:07 PM
  #44
g5mike's Avatar
what are the advantages to no cat??????? cause I have the 2.5 free flow cat and dp I'm about to bolt on
Old Jan 15, 2007 | 07:52 PM
  #45
sushidog's Avatar
Going catless is good for only 1-2hp, not worth it in my opinion, unless you're building a race car.
Old Jan 15, 2007 | 09:02 PM
  #46
sorry i was jus a lil confused to as where the sensor goes but now i know its on the dp, THANKS.
Old Jan 17, 2007 | 03:34 AM
  #47
Other then 1-2 hp, it's also good if you use leaded racing fuel while at the track. Lead can cause your cat to clog up quite quickly, and I think some other things as well. But I'm pretty sure that my track you can get 100 octane unleaded. I think it's 104 and 112 (?) thats leaded. I might be pulling these numbers out of my ass. I've only used 100 so far.
Supercharged06SS
Dec 11, 2022 04:47 PM
no_ss
Oct 18, 2015 11:58 PM
riceburner
Oct 2, 2015 05:47 PM
nathan112i
Sep 30, 2015 07:12 PM
