Downpipe question??
Old Dec 10, 2008 | 10:55 AM
hawkeyez's Avatar
Downpipe question??
I was wondering if I will lose horse power or whp by adding a 3 inch catless downpipe. I have an 06 SS/SC with gmpp stage 2 kit, GMPP header, GMPP sport cat back exhaust, Injen cai and ingalls torque dampner.
JPizzle's Avatar
You might lose some power down low, but gain it up high...
Old Dec 10, 2008 | 10:56 AM
ShortStack's Avatar
i wouldnt use a 3" with a 2.25" catback...
i would go with a 2.5
Old Dec 10, 2008 | 11:01 AM
hawkeyez's Avatar
So i would be better with the stock dowpipe and would I see better times at the track??
Old Dec 10, 2008 | 11:15 AM
ShortStack's Avatar
Not so much the stock dp..
there are 2.5 replacements that flow a little better..
matched with headers theyll be that much more noticeable in gains.
Old Dec 10, 2008 | 11:27 AM
hawkeyez's Avatar
ok thanks.
Old Dec 10, 2008 | 11:29 AM
glen229's Avatar
yeah 3" to 2.25 kinda defeats all goals
Old Dec 10, 2008 | 11:31 AM
chad463's Avatar
agreed go with a 2.5 you will enjoy it more
Old Dec 10, 2008 | 11:32 AM
hawkeyez's Avatar
That is what I was thinking. That will probably hurt my dyno numbers with my current mods right???
Old Dec 10, 2008 | 11:33 AM
glen229's Avatar
ideal for a 2.0 sc lightly modded would be a full 2.5 header back imo
youll get a wierd curve
Old Dec 10, 2008 | 11:38 AM
hawkeyez's Avatar
any ideas on who makes a good 2.5 downpipe?? and shoud I go catless???
Old Dec 10, 2008 | 11:43 AM
ShortStack's Avatar
Only go catless if you dont have emissions to worry about...
Cobalt Addiction makes a nice header that bolts to stock exhaust manifold.
http://cobalt-addiction.com/products/pages/headers.html
Last edited by ShortStack; Dec 10, 2008 at 11:43 AM. Reason: Automerged Doublepost
Old Dec 10, 2008 | 11:47 AM
hawkeyez's Avatar
Ok I will have to check it out. On the dyno will I do better with the 3inc or the 2.5 inch? How much do you think the diff will be in numbers?
Old Dec 10, 2008 | 11:50 AM
ShortStack's Avatar
2.5" will be better with the catback you have now. also the size has alot to do with the power your going to make..
I use a 3" dp with a 2.5" catback, because im not making enough power yet for a full 3". And i chose to let my headers breath, since they have a 3" collector..
Im not sure if the numbers will be much, but the difference will be noticable..
Someone once gained like 10 hp on the dyno from going down to a 2.5" catback from a 3", because they werent making enough power for the larger diameter.
Old Dec 10, 2008 | 11:55 AM
hawkeyez's Avatar
Ok I have a GMPP 2.5 cat back, GMPP header, Injen cai, GMPP stage 2, and ingalls torque dampner? 3 inch or 2.5 inch down pipe. With the 3 inch I dynoed at 235 whp and 220 torque. So shoud I save my 3 inch for later and go with a 2.5 inch for now so I can see more numbers on dyno?
Old Dec 10, 2008 | 12:13 PM
Bika's Avatar
Fail Less.
why would 3" dp and 2.25 cb defeat all goals?
it actually may help flow to have a larger diameter up front and slightly smaller in the back due to the way exhaust gasses lose velocity as they travel. exhaust gas scavenging effect.
You wont lose any power unless you have 3" header-back without enough mods push a large amount of air.
Old Dec 10, 2008 | 12:31 PM
hawkeyez's Avatar
So I should be ok then and I will have more power with the setup i have now???
Old Dec 10, 2008 | 12:35 PM
ShortStack's Avatar
Slightly smaller.. yes.. but i think a 2.25 exhaust is is a little too much...
Old Dec 10, 2008 | 01:49 PM
Bika's Avatar
Fail Less.
2.25"... blame GM for that one. probly will go 2.5" axel back eventually and keep my 3" dp.
Old Dec 10, 2008 | 04:07 PM
hawkeyez's Avatar
I like the sound of my 3in catless downpipe. Just wanted to know about the power i would gain or loose by having it on?
Old Dec 10, 2008 | 04:09 PM
ShortStack's Avatar
weve answered this a couple times...
you will gain power by going to 2.5 with a 2.25 catback
if you get a bigger cat back, get a bigger dp.
Old Dec 11, 2008 | 10:55 PM
hawkeyez's Avatar
thanks for your help
Old Dec 12, 2008 | 09:22 AM
ShortStack's Avatar
no prob.
brandon04
Oct 21, 2015 07:04 AM
no_ss
Oct 18, 2015 11:58 PM
nathan112i
Sep 30, 2015 07:12 PM
Extremespeed
Sep 29, 2015 04:34 AM
