goin turbo
I don't know that the rods have been a failure point for anyone. Pistons are usualy the failure point for most people. But, if your good with tuning and run everything safely 350 will be fine with stock internals.
I don't mean to bash Fred at all, he does great work and tunes well. But, he isn't going to have the time or patiance to get your car perfect. If your going to do it seriously you should pick up a copy of HP tuners yourself I wish I did earlier. There is only so much you can do even with a whole day of dyno tuning. You really have to drive it and tweek it for a long time until you have it perfect. I've had my turbo since this spring and it's not yet completly tuned. I haven't ever made a pull in high boost (15 or higher) to redline that behaved the way I wanted.
Waste, they are factory forged and very nicely done. I would suggest leaving everything stock rods/crank wise unless you are doing a fully built block. Cryo-ing isn't going to yeild any gain whatsoever and its not cheap.
Rods/crank are good to 450+ crank HP as per GM, way beyond what 98% of people will ever see.
Last edited by ItalianJoe1; Dec 11, 2008 at 10:14 PM. Reason: Automerged Doublepost
NEVER, I REPEAT NEVER DO THAT
Last edited by BLAZIN07SS; Dec 11, 2008 at 10:31 PM. Reason: Automerged Doublepost
Seriously?
Follow the RWD conversion project at all? Stay far, far away from JBP.
Lucky ***. I'll have to send you some VQ parts then, I lost my connect down here for cryo stuff, dude got his law degree and left the shop to start making real money. ******* people, i swear they are so inconsiderate of my needs.
Last edited by ItalianJoe1; Dec 11, 2008 at 10:34 PM. Reason: Automerged Doublepost
http://www.nwcryo.com/pricelist_master.html
not.
Last edited by ColeJJones; Dec 11, 2008 at 10:38 PM. Reason: Automerged Doublepost
Seriously?
I'm saying, for what you get, its not like its only $20 to have it done.
I'm personally thinking, HR motor, cams, 150 shot. Mid 11's on street tires, stock block.
Last edited by ItalianJoe1; Dec 11, 2008 at 10:53 PM. Reason: Automerged Doublepost
Ok, you spend $200 having the crank and rods cryoed for zero gain...
Space maybe? I haven't looked around the car at all, i'm guessing it would be a ton of custom fab to make a big single work. For 500-600whp, I would rather have dual 2871R's or something like that. Spool would be fast and hard, and high 20's boost levels on high octane/E85 would make tons of power. Needs a built block, but what doesnt.
i have a feeling we are gonna have a lot of fun with our vq's
