Drag Bags
Old Feb 24, 2009 | 11:48 PM
Hodz's Avatar
Drag Bags
I've read some stuff about these already and I have tried to search info on these too but there isnt much out there about them. Im more interested in reviews and feed back from people who have these but any info would be great. So basically do they help and are they worth buying?
Old Feb 25, 2009 | 01:32 AM
bigrroberto's Avatar
very worth it!
I havent used them personally but I know two guys that are track vets that have used them on both a cobalt and a redline. They say it dropped about .1 - .2 off their average 60'. Highly worth it. I will be getting them too this year for the track.
Old Feb 25, 2009 | 01:53 AM
tdipowered's Avatar
what the hell are they?
Old Feb 25, 2009 | 02:00 AM
KevinsKobalt's Avatar
www.airliftcompany.com
WORTH IT. easy to install. easy to maintain.
Old Feb 25, 2009 | 02:01 AM
they're inflatable bags that you basically stuff in your rear springs. You inflate them at the track and it raises your rear end up. When inflated they prevent your backend from dropping when you accelerate off the line. This keeps the weight of the car on the front wheels and increase traction alot.
Old Feb 25, 2009 | 02:09 AM
tdipowered's Avatar
ok so im to dumb to navigate that website so how much is it?
Old Feb 25, 2009 | 02:21 AM
ralliartist's Avatar
they are worth it. Pump them up high, make the rear end stiff. no squat!
Old Feb 25, 2009 | 02:29 AM
Hodz's Avatar
Im not stock but would it help a stock car as well? Also do these only work with stock springs or does it not matter?
Old Feb 25, 2009 | 02:39 AM
they are for use on the track. I mean you could pump them up for street driving if you wanted,but you'd look rediculous.
Old Feb 25, 2009 | 02:47 AM
Hodz's Avatar
Are these the correct ones for our cars?
http://www.jegs.com/i/Air+Lift/022/60844/10002/-1#
Old Feb 25, 2009 | 07:08 AM
Geoffery Kennedy's Avatar
do you leave them in there all the time even when there not pumped up
Old Feb 25, 2009 | 09:37 AM
yes, you leave them in at all times. you just inflate them to minimum PSI (5 for this application)
It is still possible to find bags even if you are lowered. Measure the vertical length of the spring at ride height and the width. just call 1-800-248-0892, extension 2, and they can tell you what kit you need.
PM me if you need more specifics, i used to work for Air Lift.
Old Feb 25, 2009 | 11:09 AM
sput's Avatar
Anyone have the specs for or have the part number for the drag bags that work with sportlines?
Old Feb 25, 2009 | 11:29 AM
again, its a "custom fit" application. get the dimensions i mentioned earlier and they can give you a part number in 5 seconds.
Old Feb 25, 2009 | 04:38 PM
sput's Avatar
Alright will do. Thank you
I just thought maybe someone had already done this. I'll post what kit I get come spring when the car comes out again. I got one last summer but it didn't fit.
Old Feb 26, 2009 | 04:18 PM
jest make sure you take the measurement with the vehicle at ride height. some cars sit lower than others so thats why you can't go based on the spring alone. if you have done weight reduction or have a heavy system or anything that can affect it, too.
Old Apr 13, 2009 | 07:37 PM
Hodz's Avatar
From what points do you measure from? The very top to the very bottom of the spring?
Old Apr 13, 2009 | 07:41 PM
ShortStack's Avatar
You know footballs work just as good .
Old Apr 13, 2009 | 07:46 PM
BoostedYards86's Avatar
x2
awesome awesome awesome.
Old Apr 13, 2009 | 07:49 PM
ShortStack's Avatar
That airliftcompany has NO prices..
im sure they are a tons more than two footballs from walmart.
Last edited by ShortStack; Apr 13, 2009 at 07:49 PM. Reason: Automerged Doublepost
Old Apr 13, 2009 | 07:51 PM
you have to buy from a dealer, not from air lift. try ordering from truckspring.com, they have good prices, or JC whitney, automotive accessories.com, etc.
Old Apr 13, 2009 | 09:15 PM
OBZ's Avatar
OBZ
How many people have actually used mini footballs and it shown success? I am very interested in this. And is it just regular footballs or JR footballs?
^Cough^
jcalvin1126
Oct 26, 2015 12:31 AM
Hugger1975
Oct 15, 2015 03:28 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
QuickSilver_SS
Sep 17, 2015 05:38 PM
QuickSilver_SS
Sep 17, 2015 11:23 AM
