Drivability without a tune
I was wondering what the "Don't do that **** ****" standard was for driving without a tune. For instance getting an aftermarket stage kit and then driving 100 miles to a place to get a tune. Doable, possible, don't do that **** ****? If its okay what precautions should I take during the journey.
i have a 2.9" pully and #42's as well as an AEM CAI, and custom 2.5" magnaflow exhaust. the pully CAN be installed before you go there. DO NOT install new injectors without a retune. i had my pully swapped for 2 weeks before i had it tuned. but i put the injectors in at the dyno shop in the parking lot. it took like 20 minutes and was really easy. there is a how-to on it in the how-to section.
good luck
x2. as long as you have athe right pully puller, this car is cake to work on.
Last edited by chevysalesman614; Apr 13, 2007 at 01:14 AM. Reason: Automerged Doublepost
You can easily drive around on the stock tune with 42#'s and a pulley. Just don't go WOT. Even GM says you can drive to the dealer for a stage 1/2 flash, and people did it before with the intense stage 3 and a MAF translator.
