drivetrain winding noise
Old Feb 5, 2010 | 06:12 PM
miked5426's Avatar
Ok i just started getting a winding noise from the engine or drivetrain. Its noticable more at speeds above 50. Its consistant with engine speed not airflow so its not the intake. Anyone hav ideas? 156 k miles. I do alota highway driving
Old Feb 5, 2010 | 06:14 PM
07cobaltguy's Avatar
wheel bearing possibly
Old Feb 5, 2010 | 06:17 PM
slowswap's Avatar
Consistent with vehicle speed or engine speed?
Old Feb 5, 2010 | 06:25 PM
miked5426's Avatar
Ok i hope. Kinda scary.. i jope thats it. Anyone eslse?
Vehicle speed. I put it n neutral at 80 just now n the soynd tones down as the vehicle slows..
Old Feb 5, 2010 | 06:45 PM
383_Stroker's Avatar
I'll go with wheel bearing too
Old Feb 5, 2010 | 06:48 PM
slowswap's Avatar
Wheel bearing is a good guess. It will get louder and quieter depending on which side when you go around a corner if it is a wheel bearing.
Old Feb 5, 2010 | 06:50 PM
miked5426's Avatar
I thot they make grinding noise wen bad?
Old Feb 5, 2010 | 06:52 PM
roboticfister's Avatar
This. It will almost go away when you turn away from the side it's bad, and will get loud when you turn into it. GM wants 300 bucks for this part, but you can get it from autozone for like 154 - it's the whole hub assembly/anti lock brake sensor. Super easy to change.
Once you think you're sure on which side it's on, jack up the car and try to wiggle the wheel from side to side, if you notice play, then it's bad. Roll it, if it resists more than usual or has a noise, it's bad.
Old Feb 5, 2010 | 06:59 PM
rnjmur's Avatar
I would say it definitely sounds like a wheel bearing.
Old Feb 5, 2010 | 07:24 PM
miked5426's Avatar
Im not hearing any difference wen turning side to side like you guys say. Its consistant wen driving straight or turning. No noise at. all wen speed is around 40 or less.
Maybe its in the beginng stages of going bad. I dontvhave any vibration at all now. And considering i drive a couple thousand miles a week, it would only b smart to replace both if it is the
Old Feb 5, 2010 | 10:37 PM
Any chance its tire noise?...
Old Feb 6, 2010 | 12:33 AM
miked5426's Avatar
Tires have **** load of tred n only .10k miles. It would b odd to have a noise like that frm them. It could b possible though
Old Feb 6, 2010 | 09:23 AM
Jazer's Avatar
Tready tires, like snow tires, will have more road noise.. It's unlikely it's that unless you noticeD this right when you put your current ones on.
Old Feb 6, 2010 | 10:21 AM
miked5426's Avatar
Nope. Tires were quet. This sound just started last week
Old Feb 6, 2010 | 11:00 AM
Billig ss/sc's Avatar
I have an issue that sounds like that. Driving straight it's fine but if I turn right there's a slight "rubbing?" sound, but when I turn left there's nothing.
Old Feb 6, 2010 | 11:15 AM
Your left side wheel bearing is probably bad
Old Feb 6, 2010 | 11:32 AM
^^so if it's the opposite side of whichever direction I turn when there's that sound? (sound is when I turn right, so it's the bearing on the left?)
Old Feb 6, 2010 | 11:51 AM
qwikredline's Avatar
ding ding ding qft
Old Feb 6, 2010 | 11:55 AM
Sweet. $150 fix, I can handle that. Any how-to's on here for fixing it?
Old Feb 6, 2010 | 07:46 PM
miked5426's Avatar
Ok this thred is bout me lol. My sound is consistent....not diff turning to either side
Old Feb 6, 2010 | 09:06 PM
Well I'm not sure unless it's your axle shaft bearing
Old Feb 7, 2010 | 03:13 AM
G11's Avatar
G11
if it is your bearing jack up the car and put your hand on the spring if you feel a vibration on the spring it is your bearing (obvisously the one you spun). also whiggle the tire up and down if you feel any movement it could be that as well. and it is super easy to install
Step one: take the wheel off
Step two: take the caliper and rotor off
Step three: undo the tie rod end bolt and with a hammer hit the spindle next to the tie rod end. the tie rod end should pop out of the spindle after a few hits (don't hit the tie rod end or the bolt)
Step four: undo the axle nut
Step five: undo the two bolts on the strut and pull the spindle away from everything, except keep it connected to the lower ball joint.
Step six: undo the three bolts that hold the bearing and there you have it is out...
to put it back together obvisously go backwards through these steps...don't forget to make sure everything is tight! Also torque the axle nut to manufactures spec!!!
Old Feb 7, 2010 | 07:31 PM
plus2ss's Avatar
Is the noise heard in every gear, or only in 5th gear. It could be a bearing in the tranny thats failing.
Old Feb 7, 2010 | 11:32 PM
miked5426's Avatar
idk i can check it out. but it just doesnt seem like a wheel bearing. i try turning and there is absolutely not change in sound when turning or anything...only in change of speed
Old Feb 15, 2010 | 09:10 PM
miked5426's Avatar
still curious as to what this sound is.
