Dual Pass Help!
Old Mar 16, 2009 | 06:26 PM
2006blackss's Avatar
Dual Pass Help!
What is the secret to switching the laminova cores? I know they're fragile so I'm tryin' to be careful but I can't seem to get them to budge. I have the o-rings and the 2 gold washers out but how do i pull them out. When i try to pull them by hand they don't go anywhere. Thanks for the help in advance.
Old Mar 16, 2009 | 06:37 PM
ShortStack's Avatar
i have a link for ya hold on.
https://www.cobaltss.net/forums/show...08&postcount=9
Last edited by ShortStack; Mar 16, 2009 at 06:37 PM. Reason: Automerged Doublepost
Old Mar 16, 2009 | 06:48 PM
Thanks, I tried searching but didn't come up w/ this one.
Old Mar 16, 2009 | 07:36 PM
Rodimus_Prime's Avatar
i used needlenose on them didnt take much to get them out
Old Mar 16, 2009 | 11:53 PM
cobalt ss/sc's Avatar
which ones do u need to switch? the top 2?
Old Mar 16, 2009 | 11:55 PM
BCobaltSS's Avatar
Wow this is becoming a broken record topic. No one has really had problems when you ask them but then when you do it they don't budge and feel like you will break them
Old Mar 17, 2009 | 07:44 AM
yea, I know I think there is just massive paranoia. They are so fragile I just wanted to be safe. I ended up wrapping a belt around them and using a pliers and it went fine. I just thought I would try to get others 2 cents so I didn't break ****, Sorry.
Old Mar 17, 2009 | 09:18 AM
qwikredline's Avatar
Place the laminova on a suitable bench with an empty carboard box or suitable container to put your cores into when removed. Take a good , new stainless steel 3/4 gear hose clamp. Place it so the nub on the inside diameter of the hose clamp is adjacent to the larger of the solid blocks in the vents on the end of the tube (easy to see) tighten the gear clamp carefully. No too tight you can collapse the vent holes. Use some channel locks to grip around the hose clamp and rotate carefully to break the seal, then twist and pull; be careful that the seals and the rings stay in the inside of the housing. When replacing lightly coat the seals with a suitable lubricant insert and away you go.
Old Mar 17, 2009 | 10:14 AM
which of these need to be switched around? when doing dual pass? ive heard guys say the big hole is the inlet and ive heard the small hole is the inlet?
Old Mar 17, 2009 | 11:57 AM
Speedytec's Avatar
Small hole is inlet, big is outlet. (Otherwise air will be trapped inside the Laminova Tube...)
Old Mar 17, 2009 | 11:59 AM
BlilBT's Avatar
^^^Like stated above the big holes are on the top & bottom which is (out) & the small holes are in the Middle which is the (in)
Jan 12, 2016 12:01 AM
cw383
Sep 30, 2015 12:41 AM
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
