dual pass install help
Old Jun 5, 2010 | 07:33 PM
roderick's Avatar
Ok so I have dual pass I installed Here is the diagram I used.
Also I have a LFP Dual pass heat exchanger and It doesnt have the bleeder on top so I have just let it run and tried to bleed it from the bleeder on the bottom. Well my temps are at 170 sitting and drop to 140 driving I know that aint right.
Old Jun 5, 2010 | 08:05 PM
crazywhiteboy89's Avatar
how are ur laminova core hook up ?
Old Jun 5, 2010 | 08:10 PM
chevysssc's Avatar
im pretty sure the middle is the out and did u swap the cores ( might be wrong can some one chime in)
Old Jun 5, 2010 | 08:41 PM
Zach06CobaltSC's Avatar
Make sure the IC pump is working and there is no air in the system.
Old Jun 5, 2010 | 08:48 PM
roderick's Avatar
Cores are like so the top and bottom are out and the middle is in. Thats how its done here https://www.cobaltss.net/forums/show...l+pass+install
Old Jun 5, 2010 | 09:59 PM
joshcsepegi's Avatar
Its air and a bad pump. My iddle was 80deg above ambient with my pump working. Swapped. Pump now I'm at 50 deg over ambient the more air I work out the better cooling it does
Old Jun 5, 2010 | 11:27 PM
roderick's Avatar
nah bro air if anything just replace the pump not to long ago with a brand new lightning.
Jan 12, 2016 12:01 AM
justinchinn
Oct 2, 2015 12:18 PM
cw383
Sep 30, 2015 12:41 AM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
