Dual Pass, Option B's, Diagrams.
So I have a dual pass endplate coming to me later this week and I have a custom option b tank coming also. The tank is custom in the regard that it will allow the coolant to flow through it, not just sit in there like the GM option b tank.
So in other words there will be 3 hoses coming off of it, one 1/4 for the bleeder, 1 for coolant to enter, and 1 for coolant to exit.
I've been told on RLF that this isn't a good idea, and am looking for more opinions.
I'm doing it this way so that I have the ability to throw some ice in it before a race to cool it down somemore. I was told it would be bad for just daily driveability though. Again, opinions or facts to disapprove or support this from anyone?
#2. Can anyone draw me up an explanatory diagram of the standard dual pass endplate setup with the option b tank.
and #3. Could anyone draw me up one for what I described above.
#4. Could someone draw me a pic of how the laminovas are supposed to be for each (if they differ?)
Keep in mind I have looked over all the GM **** and honestly all of it is really confusing hence why I'm asking to see a different one from actual people using them. Not looking to get flamed here with search the forums and other things like that, just looking for some honest help because I'm tired of sifting through all the misinformation.
Thank you in advance.
The diagrams are on this website already drawn.
and as for the coolant tank idea.. its awesome... Works wonders.. you really dont need that bleeder on the top though, because the way the coolant is ran with the enter / exit hoses, air bleeds itself into the tank.
I would keep the top nipple un covered to allow the air to escape.
I've looked and been told this or that is wrong and im so tired of trying to sift through the misinformation when i dont know what is right or wrong honestly. Help me out on where to look for the correct ones?
You use yours for daily driving and still see cooler temps?
DD all the way..
with that little extra cooling tank your talking about, i can litterally put my hand on my intake manifold and it is just warm.. not scorching like it used to be..
this is on a hot FL day too..
Ill look around for the diagrams for ya.
there are diagrams in the "dual-pass option B testimonials" thread that i have made for the dual-pass endplate with option b. there are also pictures there to help find out the best way to place the hoses, and which way to switch the laminovas
it is not a bad idea at all to run the coolant through the "ice box". i would still keep the bleed line, as it removes air from the top of the heat exchanger that wouldn't otherwise get carried out by the normal flow of the coolant. there will always be some up there unless ou have this line.
BTW, i am not just talking from what I "think" i know. I have an extra heat exchanger and the dual-pass with option B
i think leaving the top nipple uncovered is a bad idea - what if the coolant gets hot enough to over flow?
Just a tip for you. A couple guys I know have Option B with their dual pass. One of the guys I know for sure had a small "kink" if you will on his line that ran from the tank to where the original feeder neck used to be. So all he did was buy a plastic 90 to put there to keep the hose from getting the kink and it works great. Just something you might want to check before you start running your car after doing option B with dual pass.
if you run the extra tank with a enter / exit hose, it bleeeds itself..
what happend when a air bubble mixed in with some coolant hits the tank, thats open to atmostphere (meaning it isnt pressurized) ?
the air comes to the top, and only coolant flows into the hoses.
btw, here is the link to the dual-pass/option B testimonials thread
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/dual-pass-option-b-testimonials-102294/
where are you getting that it is open to the atmosphere? do you not have a pressure cap on?
Bleeding off from the h/e is pain stakingly long... if you use the un pressurized system (which is what the op is talking about) then it takes literally 1/25th of the time (not literally )
If you take off the bleeder hose, it becomes a purge valve... which is what helps bleed the air faster.
See, when i did it (with it open to atmosphere).. i made it to the end of my neighborhood... my secondary tank was completely empty, filled it... drove back to my house, it was halfway empty... topped it off
got back to the front of the hood, it lost a little bit... then after that final top off (total of 5 min) my system was completely bled and filled...
alright tenn penn i went in there and looked over the pics and everything you posted and very informative and loving it cause it's also on a RL but I was wondering if you could possibly show me how mine would be run, because the diagram i have now the laminovas are set up differently i believe and idk how it works and everything.
bump anyone know if this will work??
Last edited by daythecountrydied21; 02-10-2009 at 11:54 PM. Reason: Automerged Doublepost
pump out to stock h/e in
stock h/e out to aftermarket h/e in (preferably the cx racing dual-pass one - the small one)
aftermarket h/e out to "ice box" in
"ice box" out to inlet nipple (the middle one) on the dual-pass endplate
two outs on dual-pass endplate to a "T" fitting making it into only one line
from "T" fitting to pump in
don't forget about the bleed line. the best way is to take your 1/8 rubber hose and splice it into a "Y" fitting with enough hose to run to both heat exchangers. put the .040" orifice in the side headed to the "ice box". run the other 2 lines to the top of both h/e's to help to bleed the air from the top where it will inevitably get trapped.
that should be it. pretty much a dual-pass option B with the coolest possible fluid going into the inlet portion of the endplate/intake manifold. oh, and don't pay attention to all the haters...
EDIT: if you don't have a second heat exchanger just yet, just leave that part out for now. but be sure to pick one up later on
i'll only be running the stock h/e for now, if i feel the need i will get a cobra or cxracing and add into the mix, if you could help me out any with that, and how the laminovas would need to be setup at some point in time that would be very greatly appreciated, I just don't really understand the coolant flow on the car too well so it gets confusing very quickly to me .
EDIT. so you're saying for running with the stock h/e that diagram will work?
What about the endplate flow, in the diagram the hot fluid is coming out the middle contrary to what your idea is, what would you do about that?
to daythecountrydied, i now you have an "ice box" and dual-pass, but there is no such thing as enough cooling. i highly doubt you always have ice on hand for a good race followed by a good race. ice is a very good idea for short term - say 1/4 mile track days as long as you can keep supplying ice. but an extra heat exchanger (or a replacement - if you choose to just run the one) is never a bad idea
there's debate on using one vs using the stock inline with an after market one... idk.. i have yet to see any difference in iat's short term or long term over either setup.
and shorstack the plan is for some ice to get thrown in whenever i track it, need all the help i can get
oh, and i know you have a "ice box" but adding a second heat exchanger is never a bad idea. short stack says adding the extra h/e and bypassing the stock one or simply removing it) would work, but idk, i have never seen any comparos between the two setups. i would be inclined to believe that both running inline are better but idk
also, the extra heat exchanger would definitely help when you don't have any ice... which will most likely most all of the time. ice box is great for the 1/4 track, but any other time, your extra heat exchanger would be more beneficial
well, ice would be the point in the ice box, wouldn't it?
your "in" should be the middle nipple, you "outs" should be the outer 2. the laminovas need to be arranged so that the small holes are coming out the middle 2 cores
i'll check back in tomorrow
But its not an ice box... its an option B that has two hoses coming out of it instead of one..
it doesnt neccessarily have to run through ice.
thats all im saying lol
