dyno in a few hours !
Old Dec 10, 2007 | 01:47 PM
blk06ss/sc's Avatar
Well the day has come where i got the money and time to dyno, im going with my friends ( big turbo srt4) to do his too .. my mods are
2.6 pully with hptuners done by c/a
60lbs injectors
c/a header, c/a downpipe with high flow cat
k&n cai
corsa sport catback with resonator cut out
aeroforce interceptor ( read 280hp ) one nite in 4th, i dont know how accurate they are
AEM wideband
no cooling mods and 50000 miles still strong
videos will be posted later
what you guys think ill put down?
Old Dec 10, 2007 | 01:48 PM
M-Dub's Avatar
The no cooling mods are what is going to kill your performance!
257/ 249
Old Dec 10, 2007 | 01:49 PM
chevysalesman614's Avatar
280ish i guess. depends on what kind of dyno. good luck.
257/ 249
maybe in the summer.. but its cold out now. i think he'll be ok.
Last edited by chevysalesman614; Dec 10, 2007 at 01:49 PM. Reason: Automerged Doublepost
Old Dec 10, 2007 | 01:50 PM
M-Dub's Avatar
True, but that doesn't stop the blower from generating heat! Have fun, but the Interceptors measure Crank HP i believe!
Old Dec 10, 2007 | 01:54 PM
thedubsack85's Avatar
if he adjusted the interceptor for weight and altitude its right.. and i cant believe no cooling mods. jus remind's me of a friend with an IRL that went 2.7 with 60's and his blower lasted a month.. you must never really rev or stay up in the rev band. i dont think you will see 280..
Old Dec 10, 2007 | 01:55 PM
M-Dub's Avatar
I just know how much heat my blower generated with just my 2.85 after a run, you couldn't even put your hand on it, it was soo hot! But with the methanol after 3 runs it's still cool to the touch!
Old Dec 10, 2007 | 01:56 PM
CobaltSS 16's Avatar
around 280whp would be my guess
Old Dec 10, 2007 | 01:58 PM
Raven SS's Avatar
i had around the same set up with a cobra heat exchanger and it barely stayed alive 2 months lol
Old Dec 10, 2007 | 02:00 PM
run a stock balt a few times and touch the blower. it gets hot stock too.
i revise my guess... you will not make 280whp, more like 135, due to blowing a piston. 135 on 3 cylinders isnt too bad though
j/k.
Old Dec 10, 2007 | 02:02 PM
M-Dub's Avatar
I am deff. going to say nothing over 260 and maybe 250ish torque! You are going to get some serious heatsoak if you don't let it sit for 20 minutes after each run with ice on the blower!
Psykostevo's Avatar
I am going to say that if they put that sucker in 4th gear and then floor it from 2,500 rpms like most dyno, then the thing is not going to do well, and will give sporatic results due to knock. Lemme know
Old Dec 10, 2007 | 02:03 PM
M-Dub's Avatar
And you heard it from a tuner..... btw is the Cobie gone psyko?
Old Dec 10, 2007 | 02:05 PM
Maxim_X's Avatar
x2 Good call.
yeah um he did the pulley swap and hptune.. and with the 2.7 his exhaust sound started to change.. he then put on a cobra HE but was still running a factory exhaust including header with jus a k and n intake... BAD IDEA... he is trying to sell his car with a donated factory blower on it for what he payed for it.. not gonna happen
Old Dec 10, 2007 | 02:08 PM
M-Dub's Avatar
That can come back to haunt him.... if someone buys it takes it to a dealer and it comes back that it was destroyed, they will most likely make him take the car back and give the money back!
Old Dec 10, 2007 | 02:40 PM
blk06ss/sc's Avatar
even over summer i had the 2.7 and it was good . . i have my interceptor set on knock and boost and, under WOT in 3rd , 4th no knock maybe once and a while in 4th ill see a little other then that none, and as for the heat i know it generates alot thats why after today the balts going in the garage for winter and i start off doing ported s/c, 3.5 t/b with the meth nozzle over winter
also recently had a winter tune done so my a/f's are a little safer
i think ill be good though car hasent let me down in 2 years and no problems
Old Dec 10, 2007 | 02:41 PM
M-Dub's Avatar
Well good deal.... Methanol is gods gift to Cobalts believe me I know!
Old Dec 10, 2007 | 02:44 PM
the car wasnt destroyed.. jus maybe some melted ring land's grove's or a fried PCM.
Old Dec 10, 2007 | 03:08 PM
blk06ss/sc's Avatar
ya im excited haha got some money comming to me so im gonna do some stuff over the winter and have fun in the spring
Old Dec 10, 2007 | 03:58 PM
Psykostevo's Avatar
Mine is gone, we still have Kate's Red SS, but that's back to stock.
The kid who bought my cobalt did not take my advice, and pumped a tank of 87 Octane into it. The car lasted 17 minutes after that, and then It grenaded. He rebuilt the motor with forged pistons, and then broke an Axle, and in the process of trying to tow the car himself with the help of a buddy he ripped out the radiator and A/C condensor. :-( The car sounds like it has had it.
Old Dec 10, 2007 | 04:09 PM
roadrage06's Avatar
how does the meth kit work? Does it continuously need to be refilled? If it does, how long does it last?
Old Dec 10, 2007 | 04:45 PM
Psykostevo's Avatar
Depends on whether you have a pressure switch or one that runs constantly. If it runs constantly it will last a few hours. It it is a window switch you can go a week. (All assuming you use your window washer bottle and not the half gallon container that you can buy.
And it's cheap if you buy Wal-Marts Supertech Winter Mix Formula as your spray.
But without tuning for additional timing you gain nothing other than cooling. And if you don't own your tuning software don't add timing.
Old Dec 10, 2007 | 05:28 PM
Area47's Avatar
Rent me! per hour
240/220
::shrugs:: why aim high and be disappointed?
Old Dec 10, 2007 | 05:32 PM
Blown 4-banger's Avatar
I'm gonna say, 264/259.
Old Dec 10, 2007 | 06:40 PM
blk06ss/sc's Avatar
well sorry to say were all disapointed put down 236whp and 240tq ill post the dyno sheets tonight but at 6000rpm my a/f goes rich to prevent
#4 from going or any other damage during the winter but it was purpously tuned like that i just forgot, dyno dynamics
are these #'s low or right?
