Dyno Results.
Old Sep 10, 2008 | 11:00 AM
  #51
lsjwannabe's Avatar
Originally Posted by Area47
tune your car to what your motor likes. not what someone else says.
peak torque is 11.5
peak hp is 12.0
give or take a few
Old Sep 10, 2008 | 11:02 AM
  #52
2K5SS/SC?'s Avatar
I personally try and keep it around 11.6-11.8 across the board. If I were going to be a bit leaner it would be in the midrange and then fatten up a bit up top. I'm usually close in torque as compared to my horsepower with my 11.6-11.8 across the board though. 238whp and 230wtrq the last time I went to the dyno. That was long ago though.
Old Sep 10, 2008 | 11:05 AM
  #53
freakta's Avatar
Originally Posted by ralliartist
Tune seems a little whack. I dunno. I can see you getting over 280whp with some adjustments, but not too much more.
As for your tq, they need to tell you your peak tq number, and your tq curve needs to be somewhat flat. Like mine, I made peak tq from 4000rpms all the way to 5100rpms. and my tq never varied more than 10-12lb/ft. THAT'S CALLED TUNING.
i miss my lt1 i made peak tq from 1100 rpm to 5200rpm right around 311ft lbs. i thought the dyno was broken cause there was an extra line on the sheet but it ended up being my torque "curve"
Old Sep 10, 2008 | 11:06 AM
  #54
zrated89's Avatar
::slams head into desk::
i need to find an old dynojet to run my car on.
go to the track and see what it does.
exactly wat i said lol
Old Sep 10, 2008 | 11:15 AM
  #55
Zach06CobaltSC's Avatar
I am grabbing hptuners today and some nitrous. Not going to run the nos, but going to play around a little with hptuners and do some logging. I will get some dyno time at the dyno shop down here and do some tweaking soon. We will see what she likes.
Old Oct 14, 2008 | 10:20 AM
  #56
ebristol's Avatar
Update?
Old Oct 15, 2008 | 09:18 AM
  #57
SilverSurferSS/SC's Avatar
Updates??
Old Oct 15, 2008 | 10:00 AM
  #58
Hey hey hey whats up boys.
This is for sure a time for an update.
Well the nitrous is installed, it has not yet been ran on the dyno. AS WE SPEAK I am ordering hptuners. I am going to go ahead and run a 35shot on the dyno and see how she does with 24 degrees of timing. I am doing this after I change my spark plugs and oil, and the maintence work so I know she is running the way she should be. I will be logging it with hptuners the entire time and will post everything.
The goal is to have hptuners here by friday, no later then saturday, worse case scenario some how monday lol. Then to have my tune perfected by wednesday, and on the dyno by friday to test the 35shot.
I am pretty nervous using the 50 shot, and really don't think I want to without forged internals.
I have the following setup. Nitrous activation switch, Remote Bottle Opener switch, Bottle heater switch, Purge switch, Methanol injection controller, lean/rich shut down controller. I have so many little gadgets in my car its funny.
When you get in my car the first thing is you see the 3 gauges in the a pillar, then the wide band on the steering wheel, then the gps, then the radar detector, then the lean/rich nitrous shut down (which also watches the af/r) and then all of the nitrous switches lol.
I am enjoying the car but its time for some maintenance. Oil on the DIC is at like 25% which is time to change it, and occasionally I am getting slight knock randomly so I am backing off some timing. And to top it off I believe one of my spark plugs is bad because I randomly get a miss. I am also thinking about switching to a 5pgh nozzle, however my iat2s have not hit 140 on a 1st to 3rd back to back to back pull which amazed me.
Old Oct 15, 2008 | 10:12 AM
  #59
ralliartist's Avatar
BOOOOOOOOOMMMMMMMMM!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Back the timing off more please. lol. I would be conservative with it, like 15-18 degrees on a 35shot, and I'd still be a little scared.
Old Oct 15, 2008 | 10:15 AM
  #60
I have an 11.4 afr at wot, and I have 0 knock on wide open throttle runs. However on daily driving, at higher speeds, going up a hill i will randomly get a very slight amount of knock. So yes, I do need to back off the timing. When I am not spraying methanol, say at 0psi boost, I am getting knock going up a hill because of not methanol injection, and to much timing.
Also, with the nitrous I clearly need to back off the timing. I am thinking 10 degrees of timing + 35shot would be conservative wouldn't you?
Everyone said I would be fine to stay at 24 degrees timing on a 35 shot...I wonder why you think otherwise?
Old Oct 15, 2008 | 10:18 AM
  #61
Kibosh3's Avatar
heheh, i run 25* with a 50 shot... zach, u could honestly get away with 23-24* with ur meth kit... read ur nitrous manual (if they supplied one) ...anything under a 50 shot isnt all that necessary to retard timing.
  #62
Cause I'm scared of nitrous and I'm not ready to use it yet. I got a bunch of friends telling me to throw a 35/50/75 shot on it just like you are, but I'm going to invest money elsewhere and use nitrous as a last resort.
I've never used it and I don't really know a whole lot about it, but from what I've read, you just don't want to be too aggressive with the timing.
Good luck, I look forward to hearing what a tiny 35shot does for your!
Old Oct 15, 2008 | 10:27 AM
  #63
idunn's Avatar
100 shot
Old Oct 15, 2008 | 10:28 AM
  #64
Ryze's Avatar
a 35 shot with 650 psi pressure and solid 9-10afr made me 30whp and 26ish wtrq...lol
A 35 shot will be fine :0
Old Oct 15, 2008 | 10:29 AM
  #65
Kibosh3's Avatar
lol, u need a bottle heater...and a new cat.... lol jk
Old Oct 15, 2008 | 10:31 AM
  #66
I have a bottle heater so hopefully my bottle pressure will be much higher, but I am purchasing hptuners as we speak, and will hopefully have it hear shortly. Looks like I will be changing the plugs and oil tomorrow and have dyno time setup at the shop on tuesday. 30mins of dyno time for 50 bucks. Can't argue with that.
Old Oct 15, 2008 | 10:39 AM
  #67
I can't wait to see what the results are!!
Old Oct 15, 2008 | 10:40 AM
  #68
Update - I just bit the bullet and bought hptuners.
Where from Illinois are you silversurferss/sc
Last edited by Zach06CobaltSC; Oct 15, 2008 at 10:40 AM. Reason: Automerged Doublepost
Old Oct 15, 2008 | 10:43 AM
  #69
Peoria
Old Oct 15, 2008 | 10:46 AM
  #70
thats like right next to me lol, we should meet up sometime and go for a cruise.
Old Oct 15, 2008 | 10:47 AM
  #71
Sounds like a plan to me.
Old Oct 15, 2008 | 10:52 AM
  #72
blah, my debit card apparently has a 300 dollar limit, aka i can't buy hptuners on it right now. Sweet life lol, I am getting it raised, when the gal calls me back I am going to go ahead and order it.
Do you need to be tuned at all silver?
Old Oct 15, 2008 | 10:55 AM
  #73
Maybe....probably going with the OTT Stage 1 kit though. I'm selling my Stage 2 kit to a co-worker who has an SS/SC. Might need to fine tune her though.
Old Oct 15, 2008 | 10:58 AM
  #74
invisible's Avatar
I thought debit cards only limit was what you have in the bank....lol
Old Oct 15, 2008 | 11:00 AM
  #75
Ryze's Avatar
most of them have a 300-500 daily limit
