Dynoed the Harrop again today
Old Oct 16, 2008 | 12:15 PM
  #151
Rodimus_Prime's Avatar
so about this 75 vs 80 mm thing, if Area thinks its safe to run a 80mm to 7500 on a stock valvetrain and surely make more than 21psi, why wouldnt it be safe to use a 75mm and only rev to 7000 and make 20.5 psi???????????????????????
Old Oct 16, 2008 | 12:17 PM
  #152
ralliartist's Avatar
Originally Posted by Rodimus_Prime
i didnt take out anything and i had my tools with me
Also whats the point of revving to 7500 on valves that arent rated beyond 7000 and surely making more than 20.6psi? Id rather keep my revs lower and get the same or lower boost with the 75MM. Its a pretty safe call that on a motor that is limited to 7000 rpm the 75 is always going to work out better than an 80MM.
There are a couple reasons for revving to 7500rpms. One being that the power doesn't really drop off significantly enough to hurt you, 2 being that our gears are rediculously long, and by reving out to 7500, it puts you in a better spot in the power band when you shift.
  #153
lsjwannabe's Avatar
It has a little bit to do with that thing under your blower.
Old Oct 16, 2008 | 12:21 PM
  #154
ShortStack's Avatar
my g/fs neck?
jk..
i think hes trying to figure out how over reving the engine at a higher psi will be less devestating than a lower rpm at a roughly lower psi... You would make the boost a little faster... how about the 75 on a 7250 limit?
Old Oct 16, 2008 | 12:39 PM
  #155
Area47's Avatar
Rent me! per hour
maybe im the only nutcase here. i meth comes on at 4psi, and is spraying all it's got at 4 psi. why? because i run a stupid amount of timing 4800 rpms and below. what for? torque.
i think it's obvious you don't have a clue what you're doing. water injection and a tvs, only trapping 103?
yes im being a dick.
Old Oct 16, 2008 | 12:47 PM
  #156
Well I wouldnt have posted unless I was confused so thank you captain obvious I don't know what im doing thats the point. Some ppl also need to be a bit more conservative if its the only car they have and they dont want to break it.
LSJ wannabe - Whats the difference as far as the intake manifold with making 20.6psi at 7000 rpm or making 21-22 at 7500, I would think lower psi would be less of a problem
Old Oct 16, 2008 | 12:59 PM
  #157
lsjwannabe's Avatar
With that 2.9 you should be making around 22 psi at 7k the car does not really like it. Heat becomes a big issue
Old Oct 16, 2008 | 01:01 PM
  #158
Area47's Avatar
Rent me! per hour
how much timing. whats the afr
from 2k-7k rpms.
2.9 isn't the heat issue. the 2.75 and lower is a heat monster
Old Oct 16, 2008 | 01:04 PM
  #159
I've never seen 22psi at 7k 20.6 max with the 75mm on Keep in mind thats on 1.75 primarys on a long tube header and all 3inch exhaust still with a cat
Most I've got with the 80mm last night was 19.6, so I fail to see how 1psi is going to make things so much worse
anything you need to know should be in the logs from last night
Old Oct 16, 2008 | 01:31 PM
  #160
Area47's Avatar
Rent me! per hour
lean the car out. drop the kick on pressure for the water injection to 4-5psi. full pressure by the same.
add timing. if you want. i can throw a quick map together for you so you can compare it to your current map and see the changes.
Old Oct 16, 2008 | 02:26 PM
  #161
should I move to the 550ml nozzle?or stick with the 315
Old Oct 16, 2008 | 02:30 PM
  #162
ShortStack's Avatar
Move up.
Old Oct 16, 2008 | 02:34 PM
  #163
alrighty
Old Oct 16, 2008 | 02:36 PM
  #164
ShortStack's Avatar
Also, area isnt the first one ive heard say progressive meth is basically pointless..
when i was looking into a meth system, one of the top meth vendors actually recommended the standard kit OVER the progressive, esp with our systems becuase of how much heat it puts out, it would see better gains from full blast in low-mid psi range.
Old Oct 16, 2008 | 04:56 PM
  #165
Area47's Avatar
Rent me! per hour
maf needs some work. no biggie there. lean the car out, add timing. change the progressive to all on at X psi. also need to watch the heat when running at the track. check your system for air. there is still a lot work that has to be done to the map itself, nothing major.
Old Oct 16, 2008 | 05:37 PM
  #166
I have the dual pass option B, there shouldnt be any air
Old Oct 17, 2008 | 12:25 AM
  #167
lsjwannabe's Avatar
from 2k-7k rpms.
mine were quite manageable on the 2.75" in 95* weather they were 140 through the traps at the top of third. On the 5 gph and a 50/50 mix
Old Oct 17, 2008 | 07:46 AM
  #168
Well if 75mm is the 2.9 and its not a heat issue I'm still not seeing what is so bad about using it over the 3.1. I really liked the feel of the car with it on alot more than I do the 80mm
Old Oct 17, 2008 | 11:00 AM
  #169
lsjwannabe's Avatar
Its not horrible your car just seems to run very hot.
Old Oct 17, 2008 | 08:14 PM
  #170
i wonder if part of that is from the blower itself resting directly on the IAT2 sensor maybe getting a false reading?
Old Oct 18, 2008 | 02:28 AM
  #171
Area47's Avatar
Rent me! per hour
the sensor is insulated from it. if your sensor has a mind of it's own like mine does. then you could be running into issues.
Old Oct 18, 2008 | 01:34 PM
  #172
haha maybe thats it, i also noticed from my logs that in the sub 3000rpm range theres alot of knock due to being lean because its not hitting PE fast enough
Old Oct 20, 2008 | 08:51 AM
  #173
SCBLKRL's Avatar
what is your enrichment rate set at?
Old Oct 20, 2008 | 10:18 AM
  #174
1.4 thats not a problem its the fact that im commanding high 13s in that range
Old Oct 22, 2008 | 11:07 AM
  #175
so tonight is track night again im still up in the air on whether i want to switch back to the 75MM i really dont see how 1.5psi is so much of a problem and that would make such a difference on EGTs
