E85 on tvs
Old Feb 7, 2011 | 09:25 PM
startingline05's Avatar
E85 on tvs
i did alot of work to my car this weekend, and sense i had the valve cover off i just had to paint it but the point is getting tuned on e85 with a 2.8 pulley. i have 80 pound injectors right now. is that going to be anough or do i have to add a fuel pump for more flow, or a return fuel system?. what is the best thing for me to do fuel wise so i can get this tune?
Old Feb 8, 2011 | 01:03 AM
InfraRedline's Avatar
You will most likely run out of fuel on the spring and summer blends of E on just the 80# injectors. Return style or boost referenced system will fix your problem. Or run 98# injectors with a pump like I am doing.
Old Feb 8, 2011 | 01:34 AM
SuckMyBalts's Avatar
With the 2.8 pulley you will run out of fuel at around 6500ish rpm's. If you want to push the car to 7 or 7500 rpms you will need 1000cc injectors, aka the 98lbers that infraredline is speaking of.
Old Feb 8, 2011 | 08:16 AM
Ok well I just ordered the return style fuel system last night, where can I find the injectors? By the way I just notice on my drive to work this morning I have a p0017 code, I cleared it bur when I stopped for coffee and cranked my car up it came on again. I replaced mytiming tensioner this weekend, is it something to do with that?
Old Feb 8, 2011 | 08:36 AM
Blown07SS's Avatar
First I herd of the 98lb injectors and if u get 78lb springs wouldn't that help? Right
And where did u get the 98lbs at? And is it for e85 use only?
Old Feb 8, 2011 | 09:44 AM
jrzdude's Avatar
I hit 113% duty cycle @ redline and my AFR is sitting @ about 12.5 by that point, which isn't that bad. I know the boost reference thing will fix it, but its not an emergency @ the moment...but I'm on a 2.9 so it might be a tad different for u
Old Feb 8, 2011 | 10:52 AM
alleycat58's Avatar
I'm on 80s and the ZZP Boost Referenced system and it runs like a champ.
Old Feb 8, 2011 | 11:21 AM
coopercharge's Avatar
p0017 is crankshaft position sensor code, could be a bad sensor or something.
Old Feb 8, 2011 | 12:12 PM
Omnigear's Avatar
how low of a pulley can you go on 80's w/o boost ref?
Old Feb 8, 2011 | 02:03 PM
Yeah if you get the RSFS or BRFPS you can keep the 80's and drop a few pulley sizes. On my 2.9 and 80's on stock fuel system I was seeing 98% Idc on the fall blend at 7200 rpms, so I dont think I would have made it to redline on a 2.8
Old Feb 8, 2011 | 02:44 PM
alleycat58's Avatar
I have a 2.7 on mine, forgot to add that piece.
Old Feb 8, 2011 | 03:46 PM
Omnigear's Avatar
your on the 2.7 w/o reference/return fuel?
Old Feb 8, 2011 | 05:42 PM
^_^
Old Feb 8, 2011 | 06:02 PM
Omnigear's Avatar
^ oh harro dar i see j00 says the blind man ^_^
Old Feb 8, 2011 | 06:09 PM
Cefaln452's Avatar
get ID 1000's
Omnigear's Avatar
link ?
Old Feb 8, 2011 | 06:19 PM
alleycat58's Avatar
Akshully just got a 2.5" man pulley in the mail. :evilgrin:
Old Feb 8, 2011 | 06:25 PM
i doubt it, i think my timing is off. when i had my valve cover off this weekend i replaced the timing chain sensor to the better single piece one. when i pulled the timing tensior out it deff looked like it jumped a tooth or 2. i have no idea how to fix this. anyone know how?
Old Feb 9, 2011 | 12:05 AM
link ?
You can get them at T1racedevelopment.com
Old Feb 14, 2011 | 12:39 PM
ebristol's Avatar
i'm on 80s and the zzp boost referenced system and it runs like a champ.
i have a 2.7 on mine, forgot to add that piece.
akshully just got a 2.5" man pulley in the mail. :evilgrin:
tvs?
Old Feb 14, 2011 | 02:31 PM
alleycat58's Avatar
Yes. TVS.
Old Feb 14, 2011 | 02:42 PM
Omnigear's Avatar
zzp stough is cheapah than 1ks =p
Old Feb 14, 2011 | 03:30 PM
SCcobaltSS's Avatar
What AFR were you running?
I would ge tthe BRFPS or RSFS so you can idle easier over the monster injectors.
Old Feb 14, 2011 | 04:20 PM
At 98% IDC I think my AFR was 11.5 or so.
And I will most likely get the RSFS or BRFPS this summer, but for now here is my idle on the 1000's
YouTube - 00014.MTS
Old Feb 14, 2011 | 04:23 PM
SCcobaltSS's Avatar
Will check this when I get home. Crazy the blend difference since the car I tuned hit about 12.5 AFR since it ran out of fuel.
