Ecotec electric water pump setup
Old 04-15-2013, 07:20 AM
Tjolley's Avatar
Here is a pull from a dig.
Gm s2 with bolt ons
Old 04-16-2013, 09:26 PM
armcclure's Avatar
is that a mezeire?
Old 04-17-2013, 09:34 AM
Tjolley's Avatar
Nope a jegs brand 20gpm nothing special
Old 04-17-2013, 10:58 AM
armcclure's Avatar
Did you drill holes in the t-stat or leave it stock?
Old 04-17-2013, 11:03 AM
Tjolley's Avatar
Its stock.
Im to lazy to pull it off..i should do that though
Old 04-17-2013, 11:49 AM
armcclure's Avatar
im considering this for my new motor.. I would have to buy a new water pump anyway.
after doing a bit of reading there's really not any horros stories out there... just a lot of ppl checking in with how long there pumps have been on and still working.
btw, others interested in this, you can get a davies-craig ewp80 on ebay for 199.99 free shipping.
Old 04-17-2013, 11:58 AM
mrbelvedere's Avatar
ewp 80 blah ewp 115 yes
Old 04-17-2013, 01:28 PM
armcclure's Avatar
The 80 flows more than 20gph...
Ewp115 is only like $25 more but it has to be in a 90* section of hose, the 80 can go inline.
Old 04-17-2013, 02:33 PM
redcobalt07's Avatar
Curious to see how many miles this will last.
Old 04-17-2013, 02:46 PM
armcclure's Avatar
Mezeire pumps are rated at 3000-5000 hours.. So at even 3hrs a day driving (which is a lot) that's 1000 days min...
1.5 hr/day 2000 days... Over 5 years.
Old 04-17-2013, 03:54 PM
  #36
Tjolley's Avatar
Im doing 3 hrs a day right now
7k miles so far.
Old 05-12-2013, 04:27 PM
  #37
OneCOLDBIZL272's Avatar
Nice wright up tjolley, you did exactly what I've had in my head but wasn't sure on doing it, nore have i had the time. Looks good thou.
Old 06-07-2013, 07:21 AM
  #38
Tjolley's Avatar
Ok im past the 6 month mark with zero issues. Been upwards of 100* outside. I've done back to back to back pulls in. Im happy with this setup ill be making some improvements to it on my 2.4 lsj.
Old 06-07-2013, 07:49 PM
  #39
EXsoccer1921's Avatar
yeah my pump has been in since middle of 2010 and i haven't had one complaint.
Old 06-07-2013, 08:47 PM
  #40
Tjolley's Avatar
U running the zzp setup?
Old 06-07-2013, 09:57 PM
  #41
c130aviator's Avatar
You gave up on the machined inserts with the orings?
Old 06-07-2013, 10:17 PM
  #42
Tjolley's Avatar
No they r going into my 2.4 lsj
Old 06-07-2013, 10:36 PM
  #43
good looking forward to your build.
Old 06-07-2013, 10:41 PM
  #44
Tjolley's Avatar
U and me both still tryin to decide on valve springs bates 100 lbs seat pressure or crower 125lb seat pressure triple coil springs...hmmm
Old 06-07-2013, 10:53 PM
  #45
why so high a seat pressure? I remember area47 saying about something with engine harmonics with just 82lb springs when I did mine. Of course there was nothing wrong after my build and went down as forum phlegm in my experience.
Old 06-07-2013, 11:00 PM
  #46
Tjolley's Avatar
10,000 rpm redline is y
Wen gm did there drag N/A cars they used these springs otherwise with 20+ psi of boost and a huge cam valve float is possible. I want to make sure the valve train stays tight if u know wat i mean.
Old 06-07-2013, 11:07 PM
  #47
How long will an engine like that last? Do you spend a lot of time in 7000-10000 to use that power band or is that going to be strictly racecar?
I am finding it hard right now, for me, to justify going on with the cost of ati balancer, installing the cams, etc. Just trying to juggle daily driver vs stuff I wont use very often (high revs...) My project has always been about the DD and logevity but its hard to draw the line. I want to just keep going... Cobalt is my cocaine. Its a heck of a drug.
Old 06-07-2013, 11:22 PM
  #48
Tjolley's Avatar
Well Im ddin my cobalt for now till i finish me cavalier engine next week i hope. Then the cobalt will be strictly a weekend race car again. I ride my motorcycle lot more now with the weather being better. Well Im planing to pull the engine every winter for rings and bearings. Cuz the rings i had to go with were a lil on the thin side for my liking. But only time will tell.
Having a rev limiter that high will allow me to stay in the throttle longer than most ppl cuz i believe u r loosing momentum wen u r between gears. That's my thoughts. Just cuz ill be able to rev to 10,000 rpm dosnt mean i will every race. The engine in my car now spent alot of time in the 7000-8000 rpm range. At least 10-15 times a weekend. For the entire summer. Street racing for money is big in my area. Its not common to win or loose 300$ a weekend.
Old 06-07-2013, 11:48 PM
  #49
must be nice to have that kind of scene in your area.
Old 06-08-2013, 01:25 AM
  #50
yeah the davies craig with the controller
can't find the picture of the sensor and controller in the engine bay.
Quick Reply: Ecotec electric water pump setup
