EGT question?
Old Mar 23, 2008 | 01:27 PM
Kennyspec's Avatar
EGT question?
Hi I am almost done installing my egt gauge and i was wondering how far down the header should i mount it? This is for a turbo setup by the way. And what temps should i be looking for at WOT?? thanks.
Old Mar 23, 2008 | 01:34 PM
NJHK's Avatar
If I were you, I'd put it on the manifold itself.
Old Mar 23, 2008 | 04:04 PM
Kennyspec's Avatar
ya i was going to put it in the #4 primary in my turbo header. Just wondering how far away from the head to put it.
Old Mar 23, 2008 | 05:06 PM
07cobaltss's Avatar
closer to the motor the more accurate its going to be.
Old Mar 23, 2008 | 05:23 PM
BlackSS/SC's Avatar
Mine's about an inch away from #4 port.
Old Mar 23, 2008 | 05:28 PM
Kennyspec's Avatar
and what numbers are you seeing at wot? cruzing?
Old Mar 23, 2008 | 06:34 PM
BlackSS/SC's Avatar
Cruising is all over the place. WOT is 1500 range. Still have to get it dialed in a bit more and add some timing so it will go down a little bit.
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
