Emergency.
Old Jun 10, 2009 | 03:47 PM
Zach06CobaltSC's Avatar
Emergency.
I am helping someone with there car. It's a 2006 ss/sc with the ottp stage 1 kit and tune. The car was driving fine all day and now that were in a parking lot he goes to start and it will start, rev to roughly 2k, as the rpms drop it sounds normal, then they drop below his 850 idle line to roughly 500 and then she stalls.
The only code he is throwing is a p0443 evap code, what in the hell would cause his car to not stay running?
I do have hptuners with me, so let me know if theres anything I can do to help him.
Thanks for your time.
Old Jun 10, 2009 | 03:50 PM
turboecotec02's Avatar
Im not sure of the problem but maybe this will help others....Was that ottp just installed on the car...or was it running with it for awile?
Old Jun 10, 2009 | 03:55 PM
ottp kit was just installed sunday.
Old Jun 10, 2009 | 04:02 PM
Zooomer's Avatar
Supporting Vendor
Did the vac line come off of the TB or the EVAP solenoid?
Old Jun 10, 2009 | 04:04 PM
I don't believe so, all connections look good. When he gives it gas the car makes a VERY weird hard to describe sound. It's like a raaaaaaaaaaaaaaawr sound.....i know that doesn't help but its VERY hard to describe.
Old Jun 10, 2009 | 04:05 PM
07LaserBlueSS's Avatar
Like a WRX?
Old Jun 10, 2009 | 04:06 PM
edit: the sound is coming from the cold air intake, like directly under neath his injen cold air intake.
07laser - no his motors not blown, its an ss/sc. It will start just not idle.
Last edited by Zach06CobaltSC; Jun 10, 2009 at 04:06 PM. Reason: Automerged Doublepost
Old Jun 10, 2009 | 04:12 PM
Just checkin haha.
Old Jun 10, 2009 | 04:17 PM
damien's Avatar
Bad maf?
Old Jun 10, 2009 | 04:21 PM
chris88z24's Avatar
Sounds like a vacuum leak...
Old Jun 10, 2009 | 05:29 PM
Can someone post up a picture of the motor with all of the vaccum lines connected, maybe theres something I am missing.
There is a sound coming from the cold air intake, directly under neath the CAI. It sounds like gear whine.
ok we are getting somewhere. With the car off he tapped the gas and I heard a clicking, its the throttle body butter fly. Why is it clicking? It's like getting stuck or hitting something, why?
The butterfly in the TB is clicking and is VERY hard to move by hand, dont know if this is supposed to be hard to move or move easily without the key in the ignition, without it running etc. But with the car off, key not in etc when he taps the gas the butterfly it the TB clicks. My car does NOT do this. What would cause this?
Anyone know if a throttle body is supposed to be HARD to move by hand, like the butterfly in the TB is very difficult to move. When he touches the gas with the car off you can hear the butterfly open and close, it makes a ticking sound like its grinding against the metal.
ok so its not the TB, its just making a really odd sound coming from the CAI, like the CAI is trying to suck in the world
Last edited by Zach06CobaltSC; Jun 10, 2009 at 05:29 PM. Reason: Automerged Doublepost
Old Jun 10, 2009 | 05:38 PM
WickedSS2005's Avatar
txt sent.
You have my number fool use it
Old Jun 10, 2009 | 05:39 PM
AnthonyCM's Avatar
since its an easy thing to do...put your TB on his an see what happens? idk
Old Jun 10, 2009 | 05:40 PM
drew1991sf's Avatar
is the line attached under the fuel rail? on the intake manifold
Old Jun 10, 2009 | 05:42 PM
Its not the TB, its not the fuel rail, I don't see any lose vacuum hoses etc.
Basically it sounds like the CAI wants to suck up the world. There is a really ODD sound coming from the cai.
Old Jun 10, 2009 | 05:45 PM
drew1991sf's Avatar
is something messin with the airflow on the intake? or maybe a tear in the inlet?
Old Jun 10, 2009 | 05:59 PM
damien's Avatar
Um, my tb is easy to move when car is off....
Old Jun 10, 2009 | 06:50 PM
383_Stroker's Avatar
That's what my car did when I left the hose for the brake booster off one time.
I'm calling vacuum leak somewhere
Old Jun 10, 2009 | 08:46 PM
coopn8r's Avatar
Any news on the problem?
Old Jun 10, 2009 | 08:56 PM
Cefaln452's Avatar
vaccume leak.. replace hoses... they are a tight fit, and if they are stock they are more than likley dry rotted and cracking
No news on the problem bro thanks for asking though. I went over EVERY vaccum line, every hose, every wire, every sensor, everything. I really have NO clue what it is... But the car was towed to a dealership and we will go from there.
I don't know if I said this was a buddies car or not, but its not my car its a buddies car. However I do appreciate all of the help and so quickly.
Old Jun 10, 2009 | 09:54 PM
thc's Avatar
thc
did a hole get rubbed into the intake that could be causing the vac leak? i know my cai rubbs pretty bad where it goes thru the wheel well.
Old Jun 10, 2009 | 10:08 PM
I didn't pull the intake all the way out, but I didn't feel an actual whole. I am actually thinking its a clogged fuel filter believe it or not. The only 3 things you need for an internal combustion engine to run is fuel, spark and oxygen. The spark is fine because his plugs are new and gapped correctly from what he said, I didn't pull them, the oxygen is there because were not in outer space lol so that leaves fuel. The fuel pump will prime and the car will start, but the fuel pump or the fuel filter is not producing enough fuel to keep the motor alive.
I took off the coupler at the throttle body and ran the throttle body open and tried to start the car, no luck, tried no air filter on the cai no luck, tried with maf no luck, without maf no luck, so I really don't think its an oxygen related issue, but it could be a bad maf sensor. But to me logic would dictate that its fuel related because I have seen cars run without mafs, without cai's, just with open throttle body's etc. The cars don't like it, but they will START and stay running, just not drivable.
Old Jun 10, 2009 | 10:54 PM
19transam81's Avatar
well the evap is on the engine i think. There is also another part of that evap stuff in the canister. i had to repalce my evap stuff at 51000 miles. i also had to repalce my maf at 43000 miles. i had these same symptoms both times.
Old Jun 11, 2009 | 12:13 AM
Hopefully the guy gets it figured out, I will letcha know what the dealership says that he got it towed to when I find out. So basically let this thread die and I will update it when I find something out, later all.
