Engine Code: P1133?
Old Aug 4, 2009 | 08:48 PM
StockSS's Avatar
Engine Code: P1133?
Hey, my car got the above engine code. i recently had body work done to the car because i hit a deer and when they gave it back to me they told me there was an engine light on but they erased it and i drove the car for 10min and of course the engine light came on. That is the code that's coming up. Any idea's what it could be?
Old Aug 4, 2009 | 08:49 PM
BLAZIN07SS's Avatar
I'm too JDM for you
insufficient switching on the primary o2 sensor. pretty common with aftermarket headers
Old Aug 4, 2009 | 08:51 PM
Cobalt_1988's Avatar
Sorry to hear man but you hit a deer? LMAO how fast were you going?
Old Aug 4, 2009 | 08:57 PM
StockSS's Avatar
so just turn the code off with hp tuners? or should i try to figure out what's wrong? also i don't have a 02 sensor in the dp anymore. i just took it out and shut off 4 engine codes b/c of it. i was wondering if it's the ecu or coil packs? any idea? or it's not a big deal code and just disable it? thanks dude
i took the 02 sensor out of my dp and that's where my wideband plugs in. or are you talking about the header 02 sensor?
idk
Old Aug 4, 2009 | 09:07 PM
BLAZIN07SS's Avatar
I'm too JDM for you
its for the one in the header. you know how AFR bounces around stoich(+ and -) that is switching. also being an 07, they get kind of pissy when you dont have the rear o2 in the downpipe
Old Aug 4, 2009 | 09:11 PM
StockSS's Avatar
recommendations master?
Old Aug 4, 2009 | 09:23 PM
BLAZIN07SS's Avatar
I'm too JDM for you
get a bung for your wideband 18 inches from your head ports, put the rear o2 back in the stream, re-enable the codes except for p0420(set to "no error reported") and you can try disabling(set to no error reported) that code, its only emissions crap anyway
Old Aug 4, 2009 | 10:47 PM
StockSS's Avatar
eh. i kind of don't want to spend any more money in the car for now. lol if you weren't going to put back the other 02 sensor for the dp? it's the sensor right before the dp. i took it out disabled all the codes for it and put the wideband sensor in it's place.
suggestions ?!?!?
HEATON
Oct 16, 2015 07:21 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
