Engine power reduced
Old Jul 25, 2011 | 10:55 PM
Behaviorz's Avatar
So my car keeps saying engine power reduced for the last couple days. Car has no power once it happens and it sounds like ****, I pull over and start it a couple times and it will be back to normal and sometimes run fine for a bit and then do the reduced engine power again.. I cleaned the maf sensor, throttle body, the sensor on top of the supercharged, checked the connections on the throttle body and it still does it. I dont wanna have to bring it to a dealership if I dont have to. I got 5 codes
p0171 system to lean
p0069 Map-Barometric pressure correlation
p0121 Throttle/pedal position sensor/switch a circuit range/performance problem
p0068 Map/maf throttle position correlation
p2228 barometric pressure circuit low input
If you guys have any ideas please let me know!
Old Jul 25, 2011 | 10:58 PM
Refractor's Avatar
Sounds like the car cant get the position of the gas pedal to correlate to the position of the throttle so it panics.
This is a complete shot in the dark, but try disconnecting the battery, manually closing the throttle all the way, unplugging the throttle, and then putting everything back together again before re connecting the battery.
Old Jul 26, 2011 | 01:26 AM
rivaladore's Avatar
I remember reading about a few people that had the same problem as you a few months back. They replaced the throttle body and the problem was solved
Old Jul 26, 2011 | 10:13 AM
Behaviorz's Avatar
Im just worried about buying a new tb and that not being the problem
Old Jul 26, 2011 | 10:40 AM
dumpleRL's Avatar
my redlije did something similar but I equated the problem to the intake tube not being all the way connected
Old Jul 26, 2011 | 01:36 PM
Behaviorz's Avatar
So I scanned my car again and now this one was added p2228 barometric pressure circuit low input
Old Jul 26, 2011 | 01:41 PM
rivaladore's Avatar
Have anyone local that you could swap in their tb real quick
Old Jul 26, 2011 | 01:50 PM
Behaviorz's Avatar
Thats actually a good idea but I dont know anyone around here that has a supercharged cobalt, there all base models
Old Jul 28, 2011 | 10:40 AM
rivaladore's Avatar
This guy is selling a lsj throttle body for $60 shipped
https://www.cobaltss.net/forums/part...e-body-257240/
Old Jul 29, 2011 | 09:38 AM
ccbalt22's Avatar
mine did this the other day... just make sure all of your sensors are pluged in and working. i for got to plug in a sensor after i was changing my oil... made it about a mile and it hit...thought i blew it up.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
patooyee
Oct 1, 2015 01:07 PM
