Engine Power Reduced after loosing traction
Old Jan 25, 2011 | 06:03 PM
lightningbalt's Avatar
car lost traction today and went into Engine Power Reduced. I got it home then disconnected the battery. reconnected it now everything is good? should i worry about anything or the cel coming back on?
Old Jan 25, 2011 | 06:29 PM
Erick161's Avatar
Just make sure you have nothing loose. My car did this when my intake bolts came off my S/C'er. Would turn on, idle fine for a second, then "Engine Power Reduced" would display on the DIC.
Old Jan 25, 2011 | 06:35 PM
blue05ss/sc's Avatar
My car keeps going into "limp mode also just replaced the throttle body didnt help at all...hopefully i will find answers in this thread
Old Jan 25, 2011 | 08:05 PM
my tb was dirty and was cleaned before. along with the maf have you tried cleaning that too?
Old Jan 25, 2011 | 08:36 PM
ULWizSS's Avatar
What code did you get. Most likely a sensor going bad. P0183 knocked my car into limp mode every 5 minutes.
Old Jan 25, 2011 | 08:48 PM
Tps code i dont remember the numbers...im at work all night but ill get to a scanner tomorrow its becoming a situation now if i put to much pressure on the pedal it goes into limp...what was the cause of yours i just put a brand new tb on and it still does it
Old Jan 25, 2011 | 11:00 PM
i dont remember the numbers either. but awhile pack i did a hard pull onto the freeway and it went into limp mode and it was cause the tb and maf were dirty. but today a guy cut me off on the free way and i had to break and swerve and i spun out and then it went into engine power reduced
Old Jan 26, 2011 | 12:08 AM
Ya my tb is brand new and my maf i cleaned right b4 snow hit....i got a code about a map sensor but idk if thats actually what it is..when i push my clutch in the car revs the shiy out of it all on it own then trys to stall when im at a complete stop....plz folks help
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
patooyee
Oct 1, 2015 01:07 PM
