Engine Rebuild..Need some advice.
Old Jan 13, 2010 | 10:42 PM
redline4's Avatar
Alright with every minute im coming to the realization that the motor is fu*ked and that im going to be putting a new motor in. So can anyone give me a decent setup for the rebuild. I mean the entire thing. Pistons etc.
Old Jan 13, 2010 | 10:45 PM
DarkCobalt13's Avatar
First off, do you know that the entire motor needs replaced?
Second, what goals are you looking for from the new build?
Old Jan 13, 2010 | 10:49 PM
hatrickstu's Avatar
dude you said its still under warranty, take it in
Old Jan 13, 2010 | 10:50 PM
INFE's Avatar
How did you manage to blow up a stock cobalt? And how do you know it's blown?what's it doing?
Old Jan 13, 2010 | 11:12 PM
redline4's Avatar
I am but like i said if they give me to much **** I will just replace what needs to be replace myself.
And easy you go swimming with it.
Old Jan 13, 2010 | 11:13 PM
ls1fbody's Avatar
Haz l33t wheelz.
warranty is free
built motor = thousands of dollars.
I would put up with a lot of **** to save thousands of dollars.
Old Jan 13, 2010 | 11:16 PM
Oh, hydrolocked....... Well can you or someone you know do a teardown on it? Buddy of mine sucked up water on his Neon, we pulled it apart and he was lucky enough not to damage the cylinder walls. We just replaced the crank, bearings, rods and pistons and it runs like, well I wouldnt say champ cause its a neon but you get the picture.
Old Jan 13, 2010 | 11:57 PM
redline4's Avatar
Well the motor isn't locked up. The pistons still go up and down etc. But I have terrible compression on all the cylinders and the car just won't start. She trys to start but wont.
Old Jan 14, 2010 | 12:15 AM
HunterKiller89's Avatar
rings/valvetrain issues.
Old Jan 14, 2010 | 01:22 AM
mrbelvedere's Avatar
how much compression do the cylnders have
Old Jan 14, 2010 | 01:37 AM
insylem's Avatar
Talking
Ive read that donuts can help... smooth things over...
Donuts = WAY Cheaper then thousands of dollars.
HEATON
Oct 16, 2015 07:21 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
