Erratic Idle
Erratic Idle
Alright as most of you know i just got finisihed doing the dual pass. had a few leaks but that was just from the tank and an improperly placed hose clamp (i am freaking hoping). anyways. my idle jumps up and down, best way to describe it is sounds like a cammed lsj, cool sound, not cool because I need to fix that. Any help please.
It sounds like it gets air, no air, gets air, no air etc etc.
Have you tried cleaning the throttle body? This helped my car when it had erratic idle. It is pretty easy to do. 4 bolts (10 mm socket), one electric clip on the bottom and a vaccum hose and you will have it off. Use throttle body cleaner and a clean rag and clean all the dirt out of it, put it back in and you should be good to go!
Hopefully it works for ya!
i have cleaned the **** out of mine until you could eat off of it, and it still does it. not enough to make it stall out but still jumping from 300rpm to 1500rpm...
i'm thinking of 2 things. fuel filter and a tuning issue
I throw no engine code or anything.
i think it might be the intake gasket needs replaced? maybe?
more help? tearing down tonight again and starting over.
my dual pass is working though, guess that's my only good thing lol.
Most likely your throttle body. Pull the TB off and clean that and put it back on. If that doesn't fix the problem then you will have to go with something else...But I'd be willing to put money on it being your throttle body.
haah ok smart butt ima add u
my idle does not jump so idk last time I talked to a guy that had this problem he said it was his tune and he got rettuned and i beleive it went away. not saying its ur tune im just saying what another member was experiencing and what fixed it
mind did the same thing... mine was inthe tune tho... i had 1 pcm by zzp and one by someone on here... and the zzp one idle is irrattic almost all the time... the other one... as smooth as can be
Well i just went out to take a video and she threw a p0300.
Random misfires.
My plugs were good right before this...
any thoughts?
I am stock everything right now except for the dual pass and an intake.
Random misfires.
any thoughts?
is everything plugged in? double check cuz thats wat was wrong with my car when i threw random misfires was the cable goin to the intake manifold. if thats not it take it to the dealership if u have warranty
where are the coil packs? inside that part you have to unscrew to get the plugs out, yes?
and drew, are you talking about that line that goes to the top middle of the intake mani?
cause i broke one of the little clips on there (there's 2 sets) but the line stays on the nipple?
okay sorry i must of said something wrong lol . what sits ontop of the plugs whatever thats called i dont know in english in spanish i know( yes english = my second language) so sorry but yea whatever it is that sits on top of the plugs that u have to screw to tighten it up on my car it was loose so that was my problem.
but yea inside that part you have to unscrew to get the plugs out, yes?
yea i think we are talking about the same thing there lol
ya the one right under the fuel line, where the s/c connects to the intake manifold. maybe get a zip tie and put it on that tube so it stays on. thats my suggestion
going to go and detach all my sensors clean the tb and put everything back on then plugs tomorrow and hopefully that works.
thanks guys.
