Exedy Hyper Single is good for ???
Old Aug 29, 2010 | 01:37 AM
sunfirejoe's Avatar
Just getting close to finishin putting my car back together and still have my exedy hyper single lying around was wondering what kind of power they are rated for??? Would it survive a TVS set-up or better yet a possible twin charge??
Old Aug 29, 2010 | 01:44 AM
cli3e0339384398jk's Avatar
off ottp website "All Hyper Clutches come with a steel flywheel and a 6-puck disc with cerametallic facing, and a spring center damper. The disc is generally smaller and thinner than the OEM disc making for lower inertia and therefore quicker, easier shifting. The higher clamp load and cerametallic friction facings give approximately twice the holding torque of the OEM clutch and generally higher than other single plate clutches"
Old Aug 29, 2010 | 01:45 AM
will be fine for either setup
Old Aug 29, 2010 | 11:19 AM
Dainslaif's Avatar
Yarp. Should easily be able to handle the 400-500 a high end turbo/twincharge setup will throw at it.
Old Aug 29, 2010 | 11:26 AM
TurboTechRacing's Avatar
X2, one of the best kits out there.
Old Aug 29, 2010 | 12:44 PM
sunfirejoe's Avatar
awesoime to hear i wont sell it than
Old Aug 29, 2010 | 02:45 PM
Area47's Avatar
Rent me! per hour
max torque rating is 358ft/lbs
Old Aug 29, 2010 | 06:03 PM
jsscooby's Avatar
Is it really. dammit. I guess that clutch is off the list.
Old Aug 29, 2010 | 09:05 PM
Area47's Avatar
Rent me! per hour
i used to sell them.
Old Aug 29, 2010 | 10:03 PM
Dainslaif's Avatar
It's the strongest clutch available for our cars, as far as I know.
Old Aug 29, 2010 | 11:04 PM
terry11's Avatar
hmm... you might wanna do some research
Old Aug 29, 2010 | 11:29 PM
Flatgod's Avatar
I've been running the exedy in my TVS for 6 months now. No problems here, it's a great clutch.
Old Aug 29, 2010 | 11:40 PM
mexi_loco's Avatar
unless you do some ***** out engine work, I doubt you'll ever see more than 350 ft lbs of torque on a tvs. As for a turbo or twincharge, there's a lot of variables for power/torque rating. But exedy is one of the better clutches out there.
Solaris99
28
Mar 15, 2017 01:22 PM
agentirons
Oct 16, 2015 02:11 AM
Trav3480
Oct 1, 2015 08:17 PM
