Exhaust Backpressure & Scavenging ...
Old Jul 23, 2007 | 05:54 PM
Jmc007's Avatar
http://www.veryuseful.com/mustang/te...Scavenging.pdf
Please unlock those free ponies ...
Old Jul 23, 2007 | 06:00 PM
g5mike's Avatar
Some type of blocker on my cousins commputer,would someone mind telling me what it says???
Old Jul 23, 2007 | 11:41 PM
Matty's Avatar
Does your cousin have Adobe Acrobat Reader? I use Foxit to read the PDF files.
Old Jul 23, 2007 | 11:43 PM
Jackalope's Avatar
Yeah its 6 pages of techno babble that says to spend big bucks to get 1 or 2 more HP.
Old Jul 23, 2007 | 11:48 PM
g5mike's Avatar
okeedokeee!
Doc's Avatar
Doc
Backpressure: Friend or Foe?
Backpressure can influence in 2 places. Just at the start of when the exhaust valve opens and at cam overlap.
Figure 1. Pressure measurements at the exhaust valve during the start of the exhaust stroke at BDC to cam overlap at
the end of the exhaust stroke/beginning of the intake stroke at TDC.
Notice the positive (backpressure) spike at the far left as the exhaust valve just opens at BDC. The exhaust gases
must now push against this POSITIVE (back)pressure before it can leave the combustion chamber. The pressure
tracing is upwards and positive. Energy must be used up in order to overcome the initial positive (back) pressure in the
exhaust system before the exhaust gas is pushed out of the combustion chamber.
After we are able to overcome the positive backpressure, you see that the exhaust gas begins to travel faster and
creates a NEGATIVE pressure. The pressure tracing in the diagram is downwards or has a negative value. The more
negative a pressure becomes means that you are creating more suction or a vacuum in the system. The system is
literally sucking or pulling out exhaust gas from the combustion chamber or cylinder. This sucking or "SCAVENGING"
effect not only helps remove more exhaust gas from the cylinder. It also helps suck in more intake air & fuel mix at cam
overlap. The faster the exhaust gas travels the more vacuum it creates. We want to get as much as negative pressure
created before cam overlap.
Figure 2. Pressure at the intake port, in the combustion chamber, and in the exhaust port at cam overlap and
afterwards. Everything is interconnected. The pressure in one section affects the pressure inside another section.
At cam overlap, if you look at Figure 1., there is a reflected pressure wave traveling backwards towards the engine.
This reflected wave or "REVERSION" is what contaminates the intake charge at cam overlap and reduces or dilutes
the oxygen content coming into the cylinder. Less oxygen going in means less power. Notice the pressure at the
exhaust valve is still negative but less negative than before. This reflected exhaust wave or pulse is the second
backpressure we experience and again reduces exhaust flow speed or energy because the exhaust pulse must now
push against this pressure to move forward. A loss in flow speed means less negative pressure, or vacuum, or suck.
The bottom line to remember is that more backpressure means adding it at 2 times and that it slows down flow speed.
Slowing down flow speed reduces scavenging and efficient removal of as much exhaust gas out of the cylinder before
we start filling the cylinder back up again with fresh air (oxygen) and fuel for the next engine cycle (next set of intake,
compression, combustion, and exhaust strokes).
If you think that leaving some exhaust gas behind in the cylinder before the next intake stroke is not important, look
again at Figure 5 below. This is, once again, Jim McFarland's classic graph comparing the volumetric efficiency curve
versus the torque curve. As I stated in the cylinder head article where you first saw this, notice that these 2 curves
have the same shape but are not exactly identical or overlaid on top of each other. You would think that once you have
maxed out on the engine's breathing ability (volumetric efficiency), the torque or power curve and volumetric efficiency
would be identical. They are not. Why? Flow quality on the intake side and inefficient removal of exhaust gases out of
Figure 5. Volumetric Efficiency Curve Compared to Torque Curve. The VE Curve shows how much power you would
make if you maxed out and improved engine breathing (flow volume), flow quality, and exhaust removal. The torque
curve shows you the power if you don't pay attention to flow quality (in the low to mid rpms) and cylinder exhaust gas
removal (in the upper rpms).
Comments from Some Experts on Exhaust Backpressure:
1. Larry Widmer of Endyn on Exhaust Backpressure:
quote:
"from 21st Century Performance Book
Few tests have been done that clearly show the effect of changing back pressure. Most muffler and
exhaust comparison tests change more than one parameter simultaneously, making the identification
of exhaust backpressure as a culprit difficult.
However, Wollongong (Australia) mechanic Kevin Davis has done extensive testing of varying
backpressure on a number of performance engines.
These range from turbocharged Subaru Legacy RS flat fours to full-house traditional pushrod V8s. In
not one case has he found any improvement in any engine performance parameter with increased
exhaust backpressure.
The tests came about because Kevin has developed a patented
variable-flow exhaust that uses a butterfly within the exhaust pipe. He initially expected to use the
system to cause some backpressure at low loads 'to help torque.'
However, he soon changed his mind when any increase in back pressure proved to decrease
torque on a properly tuned engine. What increasing the backpressure does do is dramatically quiet
the exhaust.
One of the engine dyno tests carried out by Kevin was on a modified 351-4V Cleveland V8. Following
the extractors he fitted a huge exhaust that gave a measured zero backpressure. Torque peaked at
423 ft-lbs at 4700 rpm, with power a rousing 441 hp at 6300 rpm. He then dialed-in 1.5-psi (10.4 kpa)
backpressure.
As you'll see later, very few exhausts are capable of delivering such a low backpressure on a road car.
Even with this small amount of backpressure, peak torque dropped by 4 per cent and peak
power by 5 per cent. He then changed the exhaust to give 2.5-psi backpressure. Torque and
power decreased again, both dropping by 7 per cent over having zero backpressure. These
results were achieved on a large engine with a large overlap cam - one of the types some people
suggest is 'supposed' to like backpressure.
If, in fact, power does increase with increased exhaust back pressure, it is most likely the air/fuel ratio
and/or ignition timing that are no longer optimal for the altered state of engine tune."
Larry Widmer comments on the above textbook quote:
At less than WOT and peak power rpm, the diameter of the tubing should change in ID. Just as with
intake ports (unless we're just running off port volume), cross sectional area should be only sufficient
to supply the flow rate necessary to feed the engine.
High velocities, that don't incur pumping losses are the rule.
The exhaust system is much the same. Just changing backpressure is a bogus way of trying to create
the "ideal" pressure in the system. The exhaust system should work like a correctly conceived header.
It should extract the exhaust from the header, to minimize pumping pressures.
The only way to create a system that will serve as an extractor is to properly size the tubing to allow
the flow velocity to create a sort of "vacuum" behind it.
Just as with headers, creating a system that will provide the best of all worlds at all throttle positions
and rpm ranges is impossible. It's all going to be a trade-off. You can tune for the throttle positions and
rpm ranges where you desire the greatest performance, but you'll sacrifice performance at the other
end of the rpm range.
Building a system to divert the flow into a smaller system can help bolster lower rpm power, just as
with today dual runner intake manifolds, but you'll never find a dual runner intake on any engine that's
targeting the greatest performance potential possible. I should also add that such systems are
inefficient from a standpoint of weight and surface area.
For mid-performance applications, these type systems will be as popular as their costs will allow.
In our quest for "more", we seldom work to achieve mid-level (mid rpm range) performance, so just as
the gentleman who wrote the book in the post from above, we prefer to tune with the least amount of
backpressure possible. We do have to observe rules and regulations (noise levels and EPA
regulated emissions) and the systems must fit the vehicle in question without dragging the ground, so
there will always be compromises.
I suppose that I should mention that cost is another consideration. If it wasn't, a lot of our street
systems would have greater area and they wouldn't necessarily be circular in configuration either.
In the stock ITR, backpressure becomes a power "liability" by the time the engine's making 210
flywheel HP. Relative to wheel HP, if you're making more than about 11 HP more than "stock", the
system's costing you....and yes, detonation can be caused by excessive backpressure.
The other problem you face with excessive backpressure is one of reversion. The higher the
backpressure, the more inert exhaust components re-enter the cylinder. A few of these bad-guys can
really steal big hunks of power in a hurry. If you don't believe me, just run a pipe from your
exhaust tip up near the air cleaner on your next trip to the dyno. A little sniff of the exhaust will
absolutely kill your power.
2. Calculations and Comments by Dave Stadulis of SMSP Exhausts Relating Flywheel HP to Exhaust Cross-
Sectional Area (Diameter):
quote:
Here are the numbers for 16g tubing:
OD (in.)....ID (in.)...Area....%Increase......HP.......HP/in^2
2.25........2.120.......3.53.....0%............... 200.......56.66
2.50........2.370.......4.41.....25%.............. 275.......62.34
2.75........2.620.......5.39.....22%.............. 318.......59.00
3.00........2.870.......6.47.....20%.............. 400.......61.83
OD is exhaust outer diameter, ID is inner diameter, Area is tube cross-sectional area, % Increase is
increase from the prior OD, HP is Flywheel hp, and HP/in^2 is hp per square inch cross-sectional
area.
For the 2.75 in. tube, I assumed 59 HP per square inch of flow area, I used Larry's numbers for the
others....you are talking HP at the crank :
2-1/4" for up to 200HP @ the crank, 2-1/2" for 275HP, 2-3/4 for 320HP...
or 60HP (at the crank) per square inch of (cross-sectional) flow area.
This 60HP/in^2 is to get you in the general vicinity. It also is based on the inside diameter of the
tubing not the OD (i.e. 2" in your example). The ID for 2' 16g tubing is 1.87" and this will yield a limit of
165 crank HP. 2-1/4" 16g (212 HP), 2-1/2" (265 HP). Now you can get different sized tubing such as 2-
1/8" and 2-3/8" to fine-tune a vehicle but you can't get cats and mufflers in those sizes so you should
go up a size when building an exhaust in those cases.
Question: Do you have an opinion concerning the best choice for harnessing exhaust pressure waves
when a catalytic converter is present at the manifold? ... I'm just curious at a theoretical level. : Here
are the possible choices:
1. Gut the manifold mounted converter, so it acts like a pressure wave plenum, and replace the
smaller converter downstream with a larger converter (coating the exhaust to encourage light off). As
with the intake manifold, there should be some pressure wave tuning occurring somewhere in the rpm
band.
2. Use a manifold/header, which does not have a converter mounted to it, and install a pressure wave
plenum immediately in front of a larger manifold type converter downstream (once again coating the
exhaust to encourage light off). Same benefit as above, but allows some tuning flexibility since the
plenum location can vary.
3. Ignore exhaust pressure wave tuning; it's not a significant issue with a stock valve train.
SMSP replies:
I believe you can affect the overall performance of your system by the placement of the cat, since you
have a volume change when the exhaust gases enter the cat. But then temperature does become an
issue for the emissions performance of the cat.
Same goes for running an open header versus a header with a short tuned tail pipe. Tail pipe length is
very important, it just takes a lot of testing to determine what is right. I know of a guy who played with
different length tail pipes and picked up 5-6 HP on a 190+ WHP engine.
To take full advantage of the system you have test and tune, many many times. I believe a tuned
length tailpipe will get you the most power, versus running the header open (nothing after the collector)
3. John Grudinsky at HyTech Exhausts comments on the usefulness of backpressure:
quote:
I have seen where a little backpressure, helped out the very low end of a 4-cycle engine because it
had a lot of valve timing and it stopped some of the scavenging of the cylinder and (therefore) helped
the power. But as the motor revved up, the gains were diminished and it lost power on top (in the
upper rpms). There has been exhaust systems designed to actually reverse feed the cylinder through
the exhaust port, before the valve closes on overlap. It actually has worked, but it didn't seem to work
over a large rpm band but in a short (rpm) one, it worked quite well.
Old Jul 23, 2007 | 11:50 PM
Matty's Avatar
Your a helluva typer Doc.
Old Jul 23, 2007 | 11:53 PM
Jackalope's Avatar
the exhaust.
backpressure.
area.
band.
SMSP replies:
SEE! Technobabble!
Old Jul 23, 2007 | 11:58 PM
Doc's Avatar
Doc
true, it is..someone will like it
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
Sep 27, 2015 08:53 PM
