exhaust gaskets
Old Mar 2, 2008 | 10:52 AM
SS/SC05/19/05's Avatar
exhaust gaskets
Im getting my exhaust finally put on march 21st. I bought a used header and downpipe and need gaskets. I need the header gasket and the gaskets that go on the downpipe. Anyone know where i can get them and how much?? And do they make paper and metal gaskets cause id rather get a metal gasket for inbetween the motor and header?
THANKS
Old Mar 2, 2008 | 10:55 AM
BOOSSTED 06's Avatar
order them from vibrant, also some local exhaust shops carry metal gaskets
Old Mar 2, 2008 | 10:57 AM
NamedGobalt's Avatar
Is it nessesary to replace the gasket or can you reuse the stock one?
Old Mar 2, 2008 | 10:59 AM
i always replace my gaskets any time we have my exhaust off, considering they are inexpensive its just peice of mind know there is a new gasket on there. In most case the stock gasket is paper and most likely because of the heat will be in bad shape when you pull it off
Old Mar 2, 2008 | 11:03 AM
i just checked vibrant they dont have any header gaskets just 2 and 3 bolt gakets for dp's
Old Mar 2, 2008 | 11:04 AM
contact to company that makes the header you bought, they will be able to supply you a gasket
Old Mar 2, 2008 | 11:07 AM
D4u2s0t's Avatar
crate engine depot has all the gaskets you would need. I re-used my header gasket becaust it's metal and was still in good shape, but you should always change out the paper style gaskets.
Old Mar 2, 2008 | 11:11 AM
Is the stock manifold gasket metal?
Old Mar 2, 2008 | 11:12 AM
yes sir
Old Mar 2, 2008 | 11:17 AM
I just checked crate engine depot and they have an extruded manifold gasket for $10 but i have a 3" dp and want to get both gaskets at the same place.
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
