exhaust manifold tightening pattern
Old Mar 23, 2009 | 05:47 PM
Frew's Avatar
does anyone know what the exhaust manifold bolt tightening pattern for the lsj header, and how many ft/lbs of torque for each bolt.
Old Mar 23, 2009 | 05:49 PM
glen229's Avatar
10 ft/lbs and theres a pic for the pattern let me see if i can find it
Old Mar 26, 2009 | 12:33 PM
Frew's Avatar
bump for still no answer
Old Mar 26, 2009 | 01:01 PM
harryresh's Avatar
when i put my header on i started from the middle and worked my way out thus pushing any slack in the gasket outward to get a nice seel. worked for me! and 10 lb/ft is the correct amount. i would suggest putting on some anti-sieze on the bolts so the steel bolts won't corrode to the aluminum block if you ever need to remove it in the future.
Old Mar 26, 2009 | 01:07 PM
craigk_c19's Avatar
cant you justhand tighten the **** out of them?
Old Mar 26, 2009 | 02:06 PM
harryresh's Avatar
i had a leak when i first did it cuz i had a hard time getting to the bolts so i did "wrench" on them the second time and used some "copper spray a gasket" and its good now.
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
Sep 27, 2015 08:53 PM
