exhaust question
Old Jun 19, 2008 | 01:06 PM
boostaddict's Avatar
exhaust question
hey guys, I'm buying a CA 2.5" catless downpipe from someone on here. my questions are:
a) can I (and also what kind of) bolt on a cat converter at the end of the dp?
b)what length header should I use? (mid, long, shorty)
I need to know what will work so it will fit as I am a total newb when it comes to this stuff.
thanks guys!
Old Jun 20, 2008 | 12:07 AM
Sythen1678's Avatar
thanks guys!
Well mangaflow has a high flow cat converter that is also on the ZZP downpipe, it works really well and will not throw your CEL and also will allow you to pass smog with no problem.
The header will all depend on which exhaust you are looking to buy, most of the cat back's will bolt up to the STOCK dp and header, usually the shorty header is closest to stock and will allow you to bolt on to the stock dp, and then to the cat back exhaust.
but to be honest you can usualy take your exhaust to any muffler shop and they could add on any piping, after the dp and headers!
Old Jun 20, 2008 | 12:33 AM
NexTnmE's Avatar
thanks guys!
a) If you're buying a catless downpipe, why would you put a cat on it?
b) It's the same length as the stock downpipe. It should bolt up to your existing header and exhaust.
If you are just buying this part alone, it probably wont do much...maybe try -Search - Advanced - Search Titles Only - Downpipe
https://www.cobaltss.net/forums/sear...archid=4136521
Old Jun 20, 2008 | 12:41 AM
I'm buying this part catless because that's how it was made from CA and its a great deal. I'm more so asking this because if I do want to put a cat on later, I wanted to know if I would be able to...thanks for the pointers guys
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
