exhaust question
Old Jul 9, 2009 | 12:10 AM
bulletpound's Avatar
exhaust question
these are my mods right now and i would like to know should i go to 2.5inch cat-back or stay 3inch??
and before anyone says anything, i will not be going any lower than a 2.8. only thing i will do is add meth later on.
Mods:
2.8
60lbs
ottp dual pass
ottp h/e
opt b
3inch RAW Cai
JBP header(3inch)
CTI dp ( open 3inch bottle down to 2.5)
vibrant-catback (3inch)
1 step colder plugs
custom tune
Last edited by bulletpound; Jul 9, 2009 at 12:10 AM. Reason: Automerged Doublepost
Old Jul 9, 2009 | 01:20 PM
pmerritt's Avatar
from everything i've read, you should be fine with 2.5" the general consensus is if you are pushing over 300hp go 3" but with a 2.8 you're good to go.
Old Jul 9, 2009 | 01:23 PM
1Quick07SS's Avatar
you have the stock M62?
If you are pushing 300hp then yes you should get the 3".
Old Jul 9, 2009 | 01:26 PM
what im asking is if i should get the 2.5 because i already have the 3inch vibrant if you see.
my car is okay in the low end but top end it pulls really hardd
ShortStack's Avatar
A little curious...
why no lower than 2.8?
If your going to use meth inj.. i would stick with the 3"..
Old Jul 9, 2009 | 01:29 PM
Originally Posted by ShortStack
A little curious...
well im a student and the 2.8 with bolt-ons is enuff for me as a DD and im pretty much going to be done with the car add power wise after that so i just want a good solid build. ofcourse if my clutch goes and what not i will change it and i will prob get rotated mounts.
Old Jul 9, 2009 | 01:36 PM
ShortStack's Avatar
It just seems if your adding meth.. dropping the pulley size down isnt gonna be any different than adding meth... Which in itself is a completely different story.
Old Jul 9, 2009 | 01:38 PM
ye i no what you mean but meh im fine with all cooling mods and a 2.8, pulls hard enough for me, should i downgrade to a 2.5 exhaust???
Old Jul 9, 2009 | 01:50 PM
ShortStack's Avatar
If your using meth.. no...
What meth / water mixture are you planning on running?
Old Jul 9, 2009 | 01:56 PM
planning to run 75/25
Old Jul 9, 2009 | 01:58 PM
ShortStack's Avatar
3" Will be fine.
Old Jul 9, 2009 | 02:18 PM
thx 4 ur help
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
