exhaust wrap
Old Oct 11, 2011 | 12:35 PM
blacksss's Avatar
exhaust wrap
hey just wondering if this stuff is even worth throwing down money on, and how hard it is to install.
Old Oct 11, 2011 | 07:12 PM
Pyros777's Avatar
My header has been wrapped going on 2 years now. Theres no tangible difference since I installed the header wrapped already, but the theory behind it is sound: More heat in the exhaust, less heat in the engine compartment.
The only issue I've heard of is faster degredation of the metal due to the wrap retaining moisture, but have yet to find any real hard evidence.
Old Oct 11, 2011 | 07:18 PM
Powell Race Parts's Avatar
it is a pita to wrap, it does insulate and if you have issues with heat migration to the interior it is worth doing. Cobalts have a lite alloy heat shield down the length of the center tunnel that works well for insulation and so I would say not needed.
In terms of the theory of keeping the "power in the tube" maybe thats worthwhile in some applications, but realistically its easier to change your spark plugs for new, thats the sort of power improvement its worth if any;not measureable.
Old Oct 11, 2011 | 08:59 PM
black07ssc's Avatar
i don't know why but when i put it on my car i got just over 1mpg better fuel economy. underhood temps seem to be cooler but i didnt do any measurements on this
Old Oct 11, 2011 | 09:12 PM
BLue NoTe's Avatar
Im planning on wrapping my longtube when it arrives since it isn't heat treated. Pyros what header are you running?
Old Oct 12, 2011 | 12:10 AM
blacksss's Avatar
sounds good enough to me, my engine is always pretty damn hot. Are you able to put this stuff over a flex pipe, and whats a good size and thickness to go with?
Old Oct 12, 2011 | 02:37 PM
Leafydialupking's Avatar
If its mild steel you'll run into rusting issues from water retention. If its stainless you can run into both corrosion issues from air starvation (this is a super complex phenomenon that I have no understanding of other than its something that can happen somehow), or fatigue failing the stainless from the thermal loading. Oh yeah, get any oil on it and kiss your car good bye, it'll burn down. Why it does this is that the fiberglass wrap is also what they use for wicks on kerosene lamps and space heaters, so its an amazing wicking material, get an fuel source on it (oil, grease, gas, etc) and add the heat from your exhaust and that **** will burn practically forever.
Old Oct 12, 2011 | 03:10 PM
euthanasia's Avatar
That's why I went with a TLTD coating. Does the same thing as the wrap but in a chemical spray coating.
Old Oct 13, 2011 | 01:41 AM
blacksss's Avatar
i assume you can get that at a hardware or autoparts store? how much?
Old Oct 13, 2011 | 10:22 AM
Pyros777's Avatar
Exhaust Coating, Black Satin Header Coating 4 oz - Exhaust Coatings by Tech Line Coatings, Inc.
Pretty cool stuff!
Old Oct 16, 2011 | 08:47 PM
BLue NoTe's Avatar
Good link, cheap too
Old Oct 16, 2011 | 08:55 PM
SneakyMilo's Avatar
Wrapping that long-tube header will be a pain. Skip the wrap - there is no real need for it.
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
Sep 27, 2015 08:53 PM
