A/F Technical ?
A/F Technical ?
My questions are about tuning and what kind of scale the A/F is.
1) What kind of scale is the A/F ratio (constant, linear...)?
A) So this way if you had HPTuners and not a Dyno you could set it just by going from idle to WOT?
Basically I'm looking for a good explanation of if and how you would use hptuners without a dyno and a good understanding of the A/F ratio. As well is it more beneficial to dyno and tune if it is possible to tune without a dyno? Lastly is it more advantageous to tune it yourself vs. buying a pretuned chip like intense because you may have things like an aftermarket exhaust, header, intake, etc...?
Thanks so much, sorry it was long but I like thorough explanations so that I can learn and understand.
The stock O2 sensors are calibrated to be very accurate at 14.7:1 a/f but max power is somewhere between 11:1 and 12.5:1, values that the stock sensor can't tell from 10:1. they only know it's rich.
A good dyno though logs the a/f ratio at specific rpms as well as power and torque. It's like having a very detailed map and GPS instead of a compass and word of mouth directions. Sure you can get there either way but one is faster and easier.
A tune for your specific car is always better, especially if you have a local reputable tuner. Every car is slightly different/
