a few questions for tach pulley and h/e
ok well i just got my digital tach in today and hooked everything up my positive is to the pink on the back of the boost gauge and ground is on the brown. the signal hooks up to the brown and yellow wire in the coil harness. my tach only reads like 189 and idle when im idling at 900.
next i am getting a 2.6 pulley in a couple days i need to know what else do i need. i have the stage 2 belt but do i need something else. and all other components to run this thing safely.
next is my heat exchanger im deciding cetween cx ottp or zzp. whats best for my setup
I would go with the ottp heat exchanger. If you don't have an interceptor gauge I would HIGHLY recommend one. What other cooling mods do you have, if you don't have anything else I would NOT run the 2.6 pulley, your iat2's will be through the roof after 1 hard 3rd gear pull. I HIGHLY recommend you purchase methanol injection, if you are unfamiliar with it read up. Also I hate to make assumptions but I am assuming you know that you need 60lb injectors to run that 2.6 and with 60lbers you MUST get tuned. I am a tuner so if you need one let me know.
ottp for the h/e..and for a 2.6 pulley.. dont u have to modify the supercharger snout? cuz the pulley wont fit over the end.. depending on the pulley u get.. i got mine from intense when i was runnin a 2.8 and it barely fit, and siemens 60# injectors for the smaller pulley with a tune
right now im piecing the puzzle together with a header downpipe and full cat back some is coming in soon. a fujita intake and 2.6 pulley. the ottp is probablly what im going with but instead of meth im going nitrous. and hopefully if my bank account agrees im getting dual pass and custom tank for it. i will need a tune pm me and we can talk.
The cxracing one is fine, or u can get the frozenboost one like mine, it's the same as the new ottp just without the 2 welded tabs, which is no big deal, runs 180+shipping...good deal
patooyee
Oct 1, 2015 01:07 PM
