finally got my heat exchanger on
Old Nov 2, 2010 | 12:58 AM
carstedt's Avatar
what you think?
[IMG][/IMG]
Old Nov 2, 2010 | 01:01 AM
Pyros777's Avatar
I must say I think its hanging too low. I'd be afraid to scrape if I were in your shoes. Nice job on the rigging though.
Old Nov 2, 2010 | 01:02 AM
Karlen89's Avatar
What h/e is that?
Old Nov 2, 2010 | 01:03 AM
carstedt's Avatar
it does hang low but thats also why i raised the front of the car up a little bit..i had the tire just bout up in the wheel well before haha..but raised it up to where the tires flush and its fine no scrapes
Old Nov 2, 2010 | 01:04 AM
carstedt's Avatar
its a cobalt addiction front mount heat exchanger
Old Nov 2, 2010 | 01:21 AM
dontcryemokid's Avatar
yeah i put a stage 3 zzp h/e on and my bumper didnt line back up right
Old Nov 2, 2010 | 01:22 AM
carstedt's Avatar
my bumper went back on and lined up fine
Old Nov 2, 2010 | 01:28 AM
Glowbalt's Avatar
ooh can you bolt it up higher? looks good though
Old Nov 2, 2010 | 01:34 AM
blk06cbltss's Avatar
sorrry but that looks like ****. it needs to sit higher
Old Nov 2, 2010 | 01:37 AM
plaxton's Avatar
when you put the bumper back on. do you have to notch the back of the bumper or is there just enuff room for it to fit?
Old Nov 2, 2010 | 08:50 AM
carstedt's Avatar
ther is enough room for it to fit..the bumper went back on just fine
Old Nov 2, 2010 | 09:00 AM
SpeakEasy's Avatar
Looks alittle low, but
Old Nov 2, 2010 | 09:06 AM
chrisjaldin's Avatar
You should have bought ZZP stage 3 h/e. It covers very nice the entire front lower grille.
Old Nov 2, 2010 | 09:09 AM
BLAZIN07SS's Avatar
I'm too JDM for you
sorry to say that looks terrible and completely rigged.
Old Nov 2, 2010 | 09:47 AM
xxxxsh4d0wxxxx's Avatar
Should have got the ZZP S3.. It's only like $220. I agree with Blazin, it looks rigged.
I helped my buddy install his S3 and we did it without taking the fascia off, no problem.
Old Nov 2, 2010 | 09:50 AM
Supercharged Guy's Avatar
It does hang low as everybody knows but hey it's your car and your HE do as you wish
Old Nov 2, 2010 | 11:11 AM
carstedt's Avatar
you dont have to take the front clip off but it was easy to do so i took it off..it wasnt rigged thats the actual set up of it..and u can bolt it up higher if u wish u jus gotta move the bracket over so it clears the cap thats all...and yes it is my h/e and personally i lik the look of it coming down the road and it does work well..i just thought id share a couple pics just like everyone else does on these forums..but hey everyone has ther own opinions..and imo i lik it and its my car
Old Nov 2, 2010 | 12:28 PM
383_Stroker's Avatar
It appears that a cobalt addiction and a CX heat exchanger are one and the same.
And yes.. yours hangs low.. .. watch out for curbs
CX HE on my Car:
Old Nov 2, 2010 | 12:58 PM
While I do understand it is your car, and you like it.. That is not really the issue. I don't know about you, if you're lowered or not, but my front lip scrapes quite often on the under side. Your H/E appears to be roughly 2-3" lower than your lip. All I'm trying to say is I hope you're careful. Watch for **** in the road, speed-bumps, potholes, curbs, animals such as raccoons, etc. You'd be better off just fixing it and mounting it higher dude. It's not worth it.
Old Nov 2, 2010 | 02:48 PM
carstedt's Avatar
ya it is lowered..the pic was of it on the car was when the front tires were sittin up in the wheel well..i raised it up to where the tire sits just about flush with the fender now and i have no problems with it scraping...the height i had it before was to low for me neways i scraped my bottom lip quite a few times but oh well....at least u gave me some contructive criticism
Old Nov 2, 2010 | 02:52 PM
CleverOne's Avatar
Is that the drain plug on the top? flip it over so it sits flush on the crash bar and it will look a million times better.
Old Nov 2, 2010 | 02:53 PM
carstedt's Avatar
haha yes they are one in the same...simple as drilling two holes and moving it up..but mayb if i dont hook up my meth this weekend ill think bout moving it up..well see
Old Nov 2, 2010 | 02:57 PM
carstedt's Avatar
idk if i can just flip it over..id prolly just put the bracket up a little bit..itd take lik 20 minutes to take the front off..drill..and put it back on..but well see how much time i get this weekend..stupid 24hr staff duty!
Old Nov 2, 2010 | 02:58 PM
Staged07SS's Avatar
Administrator
Administrator
You did a nice job installing it. You just need to have it sit more flush against the crash bar/bumper support. Shorten up the brackets, set the heat exchanger back a bit, and you will be golden. My car is at stock ride height, and I have scrapped the lip a few times. I can only imagine what will happen to your heat exchanger if you park to close to a parking block, or hit some road debris .
Just trying to help you out man.
Old Nov 2, 2010 | 03:01 PM
CobaltVenomSS's Avatar
yea id raise it up..i busted my radiator this past weekend (dip in road didnt see it till last second) well the dip hit my heat exchanger but only scratched the bottom of it so its fine...i cant imagine what woulve happened if it was that low
