First ever fuel leak 14 years running OEM lines
Old 09-11-2018, 12:04 AM
Doug's Cobalt SS SC's Avatar
Well boys as you can see from the pics below I just sprung my first ever fuel leak after 14 years and over 200k running my same OEM lines without ever touching them.
It's a slow leak right back behind the driver seat ins the heat shield right in front of the rear driver side tire. I can tell that it's coming from one spot in the line where it clamps.
What would you guys recommend running all new OEM lines or just splicing into the bad part and replacing it with silicone lines?
Old 09-11-2018, 05:50 AM
63 Nova SS's Avatar
Up to you but if the rest is good you can just splice it. Powell makes a little kit for doing it if you want to wait a few days.
Old 09-11-2018, 06:15 AM
Flarfignewton's Avatar
I used Powell's kit when mine started leaking, works great .All you need is a small tubing cutter, something to cut the rubber line with, Teflon tape and a couple of wrenches.
Old 09-11-2018, 11:52 AM
cw383's Avatar
Id do the kit if the line seems ok elsewhere. I got the entire line ( front to back ) from GM, and even cutting it in half ( patched in a flex fuel sensor for an E85 content gauge ), and on a lift it was a bitch getting it maneuvered into place.
Old 09-11-2018, 12:08 PM
63 Nova SS's Avatar
I need to order his kit for when mine starts to leak. Only a matter of time.
Old 09-11-2018, 12:14 PM
jdbaugh1's Avatar
Is it just vibration or corrosion?
Old 09-11-2018, 01:15 PM
MINIz guy's Avatar
Corrosion. I redid mine with nylon lines when it happened to me. So far so good.
Old 09-11-2018, 02:23 PM
cw383's Avatar
They all seem to leak in the same place too
Old 09-11-2018, 02:43 PM
ProfDNS's Avatar
Mine corroded above the gas tank so it leaked everywhere. Had to replace the whole assembly.
Old 09-11-2018, 11:02 PM
The two common areas they'll leak is on top of the tank and in front of the left rear tire. The one in front of the tire is because the heat shielding GM put there holds water, dirt, saly etc.and rots the line away. Don't know the reason for the one on the tank but if I'm remembering correctly, some Cobalts were recalled for that leak.
Old 09-12-2018, 08:33 AM
joeworkstoohard's Avatar
They were, mine was. IIRC, the pump assembly had a defect in some of the plastic molding.
Old 09-12-2018, 09:51 AM
ProfDNS's Avatar
Mine was only covered by putting money down.
Old 09-13-2018, 01:40 PM
Thanks so much guys all super good info! And that makes sense about them leaking in the same spot. I keep my clean and garaged but like you said of salt is trapped under that heat shield
2.2balt
05-13-2017 08:32 PM
1LowLS
06-27-2014 08:40 PM
white07
03-16-2014 02:09 AM
turbosmart4
05-21-2013 04:26 PM
UgliestTurtle
12-18-2012 01:59 PM
Quick Reply: First ever fuel leak 14 years running OEM lines
