first successful hammer mod
I've had the car for 7 months with no working IC pump... I've tapped on it before to no avail, so tonight when the headlight change process upset me I took out some aggression on the plastic end
Coolant began to bubble then flow ftw, feels like a whole different car. I was dropping off through the top of 2nd on pulls, now it pulls so much better
you don't even have to start the car.
just have the key in the run position.
you should a) see it move coolant like zay52790 said
b) even hear the pump, but it won't be loud
c) herar the relay in the engine bay relay/fuse center click
The intercooler and engine coolant are two totally separate systems.
I don't know how much KR I had at times, I'm sure it was insane. I didn't beat on it too hard, as I knew it wasn't making power to its fullest potential. I didn't mind doing letting the ECU's safeguards give me peace of mind, I still had a warranty then..
