Fluid question.
Old Oct 29, 2011 | 10:24 AM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
Fluid question.
I have a question about types of fluids.
I'm finally getting around to installing my Dual pass and heat exchanger
Dex-Cool isn't available here unfortunately
So I have some Prestone Antifreeze/Coolant..
I was originally going to flush the system
but if it says I can mix with any color anti-freeze.. I should be okay? RIGHT?
And Should I fill it up at the tank or at the filler cap in front of the supercharger?
It's all the same system right?
Thanks in advanced
Can I technically just add that fluid to what I currently have and be OK or should I COMPLETELY flush the system and run this through?
This is what I have
Old Oct 29, 2011 | 11:12 AM
mrbelvedere's Avatar
no you just cant add any fluid to what you have the radiator and the intercooler are 2 seperate systems i would have someone either order it for you or a friend send it to you
Old Oct 29, 2011 | 11:13 AM
starkiee06ss/sc's Avatar
how do you flush the intercooler system?
Old Oct 29, 2011 | 01:17 PM
alright, it's what I'm going to do then! Thanks!
Unless an easier option is available?
Old Oct 29, 2011 | 06:30 PM
06cobalt racer's Avatar
you can get it through autozone.com. thats how i get mine here. takes a week.
Old Oct 30, 2011 | 09:00 AM
thanks man
looks like that's what I gotta' do
How much should I order?
Old Oct 30, 2011 | 09:03 AM
the intercooler systems holds 2 quarts unless you have a front mount the engine holds 2 gallons i think
Old Oct 30, 2011 | 10:05 AM
okay yea
i'm going to be installing my already mounted heat exchanger and dual pass shortly..
So If I purchase 2 gallons I should be good to go yes?
Old Oct 30, 2011 | 11:57 AM
Maven's Avatar
just use the Prestone stuff you posted.....its perfectly fine. No need to special order stuff.
Old Oct 30, 2011 | 12:18 PM
Well then..
LOL
So it IS the same stuff and I CAN mix it.
Okay
Hmn.
DarrenGC
Dec 24, 2021 01:55 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Tupp
Sep 29, 2015 11:07 PM
Bohb
Sep 27, 2015 09:11 PM
Sean Cummings
Sep 11, 2015 09:35 PM
