Flywheel hurting me?
Old Jun 23, 2008 | 11:55 PM
CobaltVenomSS's Avatar
i have a fidanza lightweight flywheel and my friend was saying that it would hurt me at the drag strip causing the wheels to spin too much...this true??? everytime ive gone to the track i get 60's of like 2.5 or so......and they did spin but i didnt drive it at the strip with the stock flywheel
Old Jun 23, 2008 | 11:57 PM
XM15's Avatar
That would be like saying your 2.85" pulley is hurting you at the track. Learn how to launch and it will help out pretty well.
Old Jun 23, 2008 | 11:58 PM
well he was comparing it to the stock flywheel
Old Jun 24, 2008 | 12:01 AM
ecotecon18s's Avatar
its funny you say that, because honestly the 2.85 is making so much boost off the line it makes it easier to spin the tires, plus it is creating more heat without any cooling mods so he is prolly knocking and heat soaking which, last time I checked, is hurting him.
Old Jun 24, 2008 | 12:05 AM
hatrickstu's Avatar
sounds like driver error to me. TYPICALLY, you want to run as light a flywheel as possible
Old Jun 24, 2008 | 12:06 AM
Super_SS's Avatar
all the flywheel does is make ur revs go up faster and fall down faster as less weight has to be turned
Otown07's Avatar
It takes horsepower to spin the flywheel. The lighter the flywheel, the more power there is available to go to the wheels. Sure it'll make it easier to spin the wheels, but that's because you're putting more power to the ground. Last time I checked, horsepower is a good thing.
Like XM15 said: Learn to launch and you'll go faster.
Old Jun 24, 2008 | 12:08 AM
ive been practicing and im getting better
Old Jun 24, 2008 | 12:09 AM
hatrickstu's Avatar
the bigger problem you have then the flywheel is the fact you have no traction mods, and you are making 30-40 more hp than stock
Old Jun 24, 2008 | 12:10 AM
let some of the air out of your tires....take a gauge with you and air em down to about 26 psi...just make sure to reinflate them before you leave the track.
Old Jun 24, 2008 | 12:11 AM
i got nitto's lol
Old Jun 24, 2008 | 12:12 AM
hatrickstu's Avatar
i got nitto's lol
fail
Old Jun 24, 2008 | 12:17 AM
fail
trust me traction mods are next....mounts and maybe a TD
Old Jun 24, 2008 | 12:19 AM
hatrickstu's Avatar
mounts and if you want to be fast at the track get some slicks
Old Jun 24, 2008 | 12:20 AM
dont they make 18" slicks?? i could get those and put them on my stock rims
Old Jun 24, 2008 | 12:23 AM
06_SS_S/C's Avatar
i thought you were getting a neon?
Old Jun 24, 2008 | 12:24 AM
hatrickstu's Avatar
dont be a fool, get 16's
Super_SS's Avatar
slicks are a must on the neon
Old Jun 24, 2008 | 12:25 AM
yea i might..havent made my mind up
Old Jun 24, 2008 | 12:59 AM
eckow8's Avatar
honestly get a solid engine mount and tranny mounts and spend some time practicing launching and you will improve your times a lot... I am stock (engine) besides an intake and I could never get traction and now i have what i have in my sig (too lazy to post it) and i still spin the tires but you can launch a hell of a lot better.... and if you do get slicks do NOT get 18's lol
Old Jun 24, 2008 | 01:15 AM
SilverSS/SC's Avatar
I have a fidenzza with a stock clutch in mine ....it only helped me .
Mounts and radial tires =
Mounts and slicks = ...your axles will love u more 2 as the soft sidewall wont shock them like radial does . Plus the sport edition F7s are 19 lbs each so u save 10lbs rotational weight .
To search the 16" rims on tire rack use a 2004 Saturn L200 .
Old Jun 24, 2008 | 01:17 AM
i rarely go to the track tho...the one here sucks...very run down..if i go to the track i just do some for fun runs...so i dont really wanna buy slicks ill barely use
Old Jun 24, 2008 | 01:19 AM
an0malous's Avatar
your friend is an idjit
he basically just said "dood, your making to much horsepower, and its making you slower"
dee de deeee
Old Jun 24, 2008 | 01:21 AM
Zach06CobaltSC's Avatar
lol at, an0malous...you always crack me up haha.
Old Sep 12, 2008 | 06:07 PM
cobalts/css's Avatar
What I meant was the flywheel was hurting you off the line. Not it was hurting your performance. I wouldn't have spent the extra money to put the lighter flywheel in it if I thought it would hurt the performance. Lol You need some sticky tires and some practice and it will help you. I just meant with the street tires and nothing else to help you it would get out of the hole a little better with the stock flywheel on the street tires you have.
jas09ss
Sep 26, 2015 01:06 PM
n20saturn
Sep 21, 2015 01:50 AM
ashalle2
Sep 16, 2015 10:36 PM
brett.higgins3
Sep 14, 2015 01:48 PM
