Flywheels...
hyper single
The whole assembly weights in at 26.155 lbs
The Flywheel weights in at 11.92 lbs
Disc at 3.08 lbs
Pressure plate at 10.87 lbs
the stock flywheel is about 23lbs
hyper single is the best setup for the price of $1050 from thmotorsports
Disc at 3.08 lbs
There is no way to use a Fidanza flywheel with the Exedy clutch. The Exedy clutch can only be ordered as a kit with the flywheel anyhow. Exedy designed the clutch/flywheel to work together as a dynamic combo. Besides the pressure plate being forged aluminum on the Exedy will reduce weight as well since other clutches are made from stamped steel.
how good is the exedy stage 1 clutch kit compared to stock??? is it alot lighter then the whole stock system(inc.flywheel, pressure plate and disc)? not looking to get a clutch thats going to be superstrong since im not going to be building my car up for big horsepower.
