2007 stage 2 tune number
Hello. I just got stage 2 installed at the dealer today, and only have a 6,500 rev limit. They said they flashed the pcm. I think they might have flashed the wrong code into it? Any way does any body know the # for the stage 2 tune for a 2007....... or any way i can prove to them that they flashed it wrong????
I did search but only found the #'s for 2005 and 2006's.
take your car back to the dealer you did not get the flash DONT GET ON IT YOUR CAR WILL GO BOOM I CANT STRESS THIS ENOUGH , tell them they didnt flash the car dont leave until they flash it, your redline NEEDS to be at 7,000 rpm's
^ Very important man hes 100% right. +rep for giving him the warning. Do not go full throttle, do not beat it. Get that car back and make them do it the right way.
ok, I found my calibration #'s for an 07 it is 12614366 & 12614368. Now is there any way the dealer can tell if this is in my car. Can they just scan it and look up the cal #'s to see that they put in the wrong flash?
http://tis2web.service.gm.com/tis2web
Plug your VIN # in here and it should tell you what cal you have .
after a little talk with the shop foreman he agread to take my car in to check the callibration. guess what it was wrong. anyways he reflashed it and it is much better. thanks for your help guys.
Are those the calibration #'s it's supposed to have to run stage 2? Or are those the stock numbers? I am asking because I just got stage 2 installed and I have those calibration numbers you posted.
Sep 28, 2015 12:51 PM
