ford injectors
Old Aug 16, 2008 | 01:02 PM
simmonsnick's Avatar
ford injectors
what other cars use the same style injectors?? it looks like ford does maybe vw and some others is that true??you can find some cheap injectors if that is true on e bay like green top 42s bosch and alot of diff lb/hr's too!!!
Old Aug 16, 2008 | 01:54 PM
Josh@ottp's Avatar
You will still need a harness for the green tops but they are a good injector. You won't be able to make much power on them though.
Old Aug 16, 2008 | 01:58 PM
brett5's Avatar
yea you will need a whole new harness for the same injectors and if you get a diff size then you need the harness and a tune
many people go this route when they switch to 60's
Old Aug 16, 2008 | 02:13 PM
many people go this route when they switch to 60's.
like the harness they sell on zzp and if this is so then you can get 72s??and i have hp tuners!!!!!i can go to the junk yard and get the right plugs i bet!!
im running a 3.1 pulley they would help alot???
Last edited by simmonsnick; Aug 16, 2008 at 02:18 PM. Reason: Automerged Doublepost
Old Aug 16, 2008 | 02:17 PM
brett5's Avatar
yes you can if you know how to tune
and anything below a 2.8 you want at least 60's so it would depend if you where dropping pulley sizes
hell personally to be safe i say anything below 3.00 get 60's
Old Aug 16, 2008 | 02:19 PM
i can go to the junk yard and get the rigth plugs for the injectors i bet!!
Old Aug 16, 2008 | 02:21 PM
brett5's Avatar
if you get lucky probably
Old Aug 16, 2008 | 02:35 PM
i think i will go walk around tomarrow and see how about saab turbo injector??
Old Aug 16, 2008 | 02:38 PM
brett5's Avatar
i'm sure it would work.. don't know tho i know they are bosch.but don't know if they have different sizes for different 4 bangers... someone on here will know tho
Old Aug 16, 2008 | 02:45 PM
how about bmw m3 42lb/hr lucas injetors??
i will find injectors for cheap!!!!do they have to be high impedance
Last edited by simmonsnick; Aug 16, 2008 at 03:00 PM. Reason: Automerged Doublepost
Old Aug 16, 2008 | 03:35 PM
Josh@ottp's Avatar
Why don't you just buy 60's with a harness? They are $230. Used injectors can be a headache sometimes, and if you splice the wires it will cost almost the same if you count your time.
Old Aug 16, 2008 | 06:36 PM
runriot's Avatar
my 42's that I had put in, (replaced with 60's a year later) were Ford Injectors. They clipped right into our harness if I remember correctly. I think zip ties were usedto hold it on there though, as they didnt "lock" in. Sounds ghetto, and it was, wich is why once I learned I had 60's installed and Spooner tune for them. It worked though, drove the car for a year like that, never a problem.
Hell they are sitting here in a box, give me ten bucks and shipping and they are yours....
Old Aug 16, 2008 | 06:50 PM
theneelster's Avatar
You don't need 72's because no lsj will ever make more than 500hp...flame shield on!
PS-->Plugs are not injectors...
Old Aug 16, 2008 | 06:52 PM
SI FTL's Avatar
I didn't read to much on this thread, just your opening statement. I make injectors at delphi and a lot of them look identical, just as the connecting pods are all exactly the same through any manufactuer (ford rousch, chevy, kia..) I wouldn't just start plug and playing injectors though, they have different leak rates, calibrated at different intervals all creating different dynamic and static flow. Some have different sized filters as well. ( If i didn't answer your question im sorry, haaha thats just what i got when i read it quick)
Old Aug 16, 2008 | 07:03 PM
Josh@ottp's Avatar
Without any other fueling sources 60's will be maxed at around 320whp on stock fuel pressure.
Old Aug 16, 2008 | 10:14 PM
um no but u have to plug them to the harness so u need the plugs to match!!read before u flamm
Old Aug 16, 2008 | 11:14 PM
reading>me...after all I'm drunk. The old splice and solder, I get it...don't agree with it but get it.
Old Aug 16, 2008 | 11:28 PM
Smarty Art's Avatar
I hope your joking.
Old Aug 17, 2008 | 01:07 AM
Josh@ottp's Avatar
Originally Posted by Smarty Art
I hope your joking.
I'm not.... ever heard of safety? Injectors are not supposed to be run above 80% idc's it's an industry standard, doing so is just foolish.
Old Aug 17, 2008 | 04:02 PM
Smarty Art's Avatar
I'm aware of that.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Fearedbynone
Apr 14, 2016 03:25 AM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
Bohb
Sep 27, 2015 09:11 PM
