friend just got the stage two and problem....
the car stumbles under throttle and the check engine light came on, also the car doesn't pull. when he got back home he noticed a hose had been unplugged and he plugged it in the most obvious place he saw but im thinking the tech messed up. i have a pic:
are these two hose supposed to be the other way around?
they are the ones on the WGA looking thing.
Try it now that it's all plugged in and that looks right. Check the plugs too. What are they, what's the gap?
And that's a By-Pass Valve (BPV), not a WGA
Last edited by WickedSS2005; Apr 17, 2009 at 05:54 PM. Reason: Automerged Doublepost
Stop right there.
1) Take out the Pul-somethings (Pulsar, w/e)
2) Get A set of copper 1 step cloder NGK's, they used to be BKR7E's, but NGK changed the part number
3) Gap at 36-40, w/e feels the best
thats the last thing u wanna do.......u gotta rember about the learning curve on our cars........it u erase sum codes there is always the possibility of making it go into limp mode and thats the last thing u want
so the code was a p0300 most likley.....and those vaccum lines for the by-pass actuator that were unplugged could easily cause that, since unmetered air is entering the motor. Plug it all up right, and go take it for a spin.
i agree thats what i run in my car
he said it was two cylinders misfiring. also can getting those two vac lines swiched going to the BPV cause cylnders to misfire?
Last edited by Forverzero89; Apr 17, 2009 at 08:10 PM. Reason: Automerged Doublepost
its titanium grey
and my mods are in sig. with open dump im faster than a speed 3. and yea i love it. rare with good looks and fast(ish)
